Is it possible to remove the 1/2 inch flare fitting that comes with dryers? The fitting will not come off. It seems like when it was installed that some type of sealant/glue was used. I am in Mexico and I cannot find hoses with 1/2 fittings. I can only find hoses with 3/8 fittings. My plan was to remove old fitting and install new fitting with 3/8 flare on it so I could attach hose. Any suggestions would be appreciated.
