Discuss
How long are heat cycles? flooded dryer
 in
Dryer Repair
I have a dryer that was in my basement during the flood. I dont think the dryer came up enough
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » How long are heat cycles? flooded dryer
  #1 (permalink)
Old 09-02-2011, 04:18 AM
Junior Member
personalt is on a distinguished road
Default How long are heat cycles? flooded dryer
Brand: Maytag   Age: Less than 1 year
I have a dryer that was in my basement during the flood. I dont think the dryer came up enough to do any damage but I wanted to inspect it first.
glow plug comes on and burner fires up fine. How long should I expect the burner to run each time the flame comes on? It is based on a timer or a sensor? It seemed the heat only came on for maybe 15 seconds at a time but it did feel like it was making it hot enough so there may not be a problem
Is 15 seconds or so of flame each time it comes on correct?
  #2 (permalink)
Old 09-02-2011, 06:54 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Flame time depends on the temperature setting; and whether you're using timed dry. or sensor-drying. During timed dry cycles, the thermostats control the cycling of the heat. This is also controlled by the heat temperature setting.
During the sensor drying cycle, the flame is controlled by the moisture sensor. If water made it up to the dryer door, you may want to clean off the moisture sensor contacts (In a Maytag dryer, they're the two long metal bars in the front of the dryer compartment)with alcohol.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool stackable washer/dryer - washer advances cycles but takes a long time LynThereDoneThat Washer Repair 4 08-24-2010 07:38 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Bosch no heat and long cycles dsm1212 Dishwasher Repair 1 09-12-2009 08:17 AM
Dishwasher does not heat water - cycles too long shishilla2002@yahoo.com Dishwasher Repair 0 08-10-2009 11:13 AM
Dryer elements cycle off and on making long drying cycles showmewarrior Dryer Repair 1 04-19-2009 12:39 PM
