Discuss
Whirlpool gas dryer, no heat, timer doesn't advance
 in
Dryer Repair
Dryer runs, but has no heat. Timer will not advance using "Automatic". However, it will advance under "Timed". Neither cycle
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool gas dryer, no heat, timer doesn't advance
  #1 (permalink)
Old 08-31-2011, 06:30 PM
Junior Member
jeffmaaske is on a distinguished road
Default Whirlpool gas dryer, no heat, timer doesn't advance
Model Number: LGR7648PQ0   Brand: Whirlpool   Age: 5 - 10 years
Dryer runs, but has no heat. Timer will not advance using "Automatic". However, it will advance under "Timed". Neither cycle has heat.
Based on some other posts, I suspect the solenoid coils. Is this correct, or should I do something else first.
Ads By Google
Related Models
Whirlpool LGR7648PQ0 29" Gas Dryer
Whirlpool LGR7648PQ1 29" Gas Dryer
Whirlpool LGR7648PT0 29" Gas Dryer
Whirlpool LGR7648PT1 29" Gas Dryer
Whirlpool LGR7848DQ0
Whirlpool LGR7848DQ1
Whirlpool LGR7848DZ0
Whirlpool LGR7848DZ1
Whirlpool LGR7858AN0
Whirlpool LGR7858AN1
Whirlpool LGR7858AN2
Whirlpool LGR7858AW0
Whirlpool LGR7858AW1
Whirlpool LGR7858AW2
Whirlpool LGR8620PG0 29"gas Dryer
Whirlpool LGR8620PG1 29"gas Dryer
Whirlpool LGR8620PW0 29"gas Dryer
Whirlpool LGR8620PW1 29"gas Dryer
Whirlpool LGR8646LG0
Whirlpool LGR8648LG1 29"gas Dryer
Whirlpool LGR8648LQ0
Whirlpool LGR8648LW0
Whirlpool LGR8648LW1 29"gas Dryer
Whirlpool LGR8648PG0 29"gas Dryer
Whirlpool LGR8648PG1 29" Gas Dryer
Whirlpool LGR8648PQ0 29" Gas Dryer
Whirlpool LGR8648PQ1 29" Gas Dryer
Whirlpool LGR8648PW0 29"gas Dryer
Whirlpool LGR8648PW1 29" Gas Dryer
Whirlpool LGR8857EQ0
Whirlpool LGR8857EQ1
Whirlpool LGR8857EQ2
Whirlpool LGR8857EQ3
Whirlpool LGR8857EZ0
Whirlpool LGR8857EZ1
Whirlpool LGR8857EZ2
Whirlpool LGR8857EZ3
Whirlpool LGR8858DQ0
Whirlpool LGR8858DQ1
Whirlpool LGR8858DZ0
Whirlpool LGR8858DZ1
Whirlpool LGR8858EQ0
Whirlpool LGR8858EQ1
Whirlpool LGR8858EQ2
Whirlpool LGR8858EQ3
Whirlpool LGR8858EZ0
Whirlpool LGR8858EZ1
Whirlpool LGR8858EZ2
Whirlpool LGR8858EZ3
Amana LGS10AW Washer - Top Loading
Amana LGS19AW Dryer - Gas
Amana LGS33AW Dryer - Gas
Amana LGS34AW Washer - Top Loading
Frigidaire LGS389FEA Frigidaire/gas Range
Whirlpool LGT5434AN0
Whirlpool LGT5434AQ0
Whirlpool LGT5434AW0
Whirlpool LGT5436AN0
Whirlpool LGT5436AW0
Whirlpool LGT5624BN0
Whirlpool LGT5624BN1
Whirlpool LGT5624BN2
Whirlpool LGT5624BQ0
Whirlpool LGT5624BQ1
Whirlpool LGT5624BQ2
Whirlpool LGT5624BW0
Whirlpool LGT5624BW1
Whirlpool LGT5624BW2
Whirlpool LGT5624DQ0
Whirlpool LGT5624DQ1
Whirlpool LGT6634AN0
Whirlpool LGT6634AN1
Whirlpool LGT6634AN2
Whirlpool LGT6634AQ0
Whirlpool LGT6634AQ1
Whirlpool LGT6634AQ2
Whirlpool LGT6634AW0
Whirlpool LGT6634AW1
Whirlpool LGT6634AW2
Whirlpool LGT6634DQ0
Whirlpool LGT6634DQ1
Whirlpool LGT6634DZ0
Whirlpool LGT6634DZ1
Whirlpool LGT6638AN0
Whirlpool LGT6638AN1
Whirlpool LGT6638AN2
Whirlpool LGT6638AQ0
Whirlpool LGT6638AQ2
Whirlpool LGT6638AW0
Whirlpool LGT6638AW1
Whirlpool LGT6638AW2
Whirlpool LGT6638DQ0
Whirlpool LGT6638DQ1
Whirlpool LGT6638DZ0
Whirlpool LGT6638DZ1
Whirlpool LGT7646AN0
Whirlpool LGT7646AQ0
Whirlpool LGT7646AQ2
Whirlpool LGT7646AW0
Whirlpool LGT7646AZ0
Whirlpool LGT7646AZ2
Whirlpool LGT7646DQ0
Whirlpool LGT7646DQ1
Whirlpool LGT7646DZ0
Whirlpool LGT7646DZ1
Whirlpool LGT7646EQ0
Whirlpool LGT7646EQ1
Whirlpool LGT7646EQ2
Whirlpool LGT7646EQ3
Whirlpool LGT7646EZ0
Whirlpool LGT7646EZ1
Whirlpool LGT7646EZ2
Whirlpool LGT7646EZ3
Whirlpool LGT7848AN0
Whirlpool LGT7848AQ0
Whirlpool LGT7848AQ1
Whirlpool LGT7848AQ2
Whirlpool LGT7848AW0
Whirlpool LGT7848AZ0
Whirlpool LGT7848AZ1
  #2 (permalink)
Old 09-05-2011, 05:04 PM
Junior Member
Default Whirlpool gas dryer now has heat!
Purchased the solenoid coil kit. Installed them in 10 minutes. Problem resolved.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Dryer timer wont advance and no low heat coachfrancisco Dryer Repair 0 08-15-2011 06:59 AM
Whirlpool Dryer Timer Fails to Advance. Heat? Well, sometimes. XtremeRob Dryer Repair 17 08-02-2011 09:34 PM
Maytag gas dryer. Timer does not advance and does not heat. lfregia Dryer Repair 1 11-28-2010 06:46 AM
Timer does not advance dryer runs no heat Rmelc1 Dryer Repair 2 07-24-2009 01:10 PM
Whirlpool dryer timer won't advance Hzep Dryer Repair 1 01-28-2008 03:22 PM
