Discuss
Dryer trips breaker
 in
Dryer Repair
The dryer just started tripping the breaker yesterday. Can you tell me what the problem may be? We reset breaker
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer trips breaker
  #1 (permalink)
Old 04-06-2009, 04:59 PM
Junior Member
rsmotorsports is on a distinguished road
Default Dryer trips breaker
Model Number: SDE405DAYW   Brand: Maytag   Age: 5 - 10 years
The dryer just started tripping the breaker yesterday. Can you tell me what the problem may be? We reset breaker and it runs for a few seconds then trips again.
Ads By Google
Related Models
Maytag SDE405DAYW Dryer - Ele
Maytag SDE4606AYW Dryer - Ele
Maytag SDE4606AZW Dryer - Ele
Maytag SDE505DAYQ Dryer - Ele
Maytag SDE505DAYW Dryer - Ele
Maytag SDE505DAZW Dryer - Ele
Maytag SDE515DAYW Dryer - Ele
Maytag SDE515DAZW Dryer - Ele
Maytag SDE5401AYQ Dryer - Ele
Maytag SDE5401AYW Dryer - Ele
Maytag SDE5401AZW Dryer - Ele
Maytag SDE5701AYQ Dryer - Ele
Maytag SDE5701AYW Dryer - Ele
Maytag SDE5701AZW Dryer - Ele
Whirlpool SDF3700W0
Whirlpool SDF3700W2
Whirlpool SDF3700W4
Whirlpool SDF3700W5
Whirlpool SDF3700W6
Whirlpool SDF4000W0
Whirlpool SDF4000W1
Whirlpool SDF4500W0
Whirlpool SDF4500W1
Whirlpool SDF4500W2
Whirlpool SDF4500W3
Whirlpool SDF4500W4
Whirlpool SDF5000W0
Whirlpool SDF5000W1
Whirlpool SDF5000W2
Whirlpool SDF5000W3
Whirlpool SDF5000W4
Whirlpool SDF5000W5
Whirlpool SDF5000W6
Whirlpool SDF6000W0
Whirlpool SDF6000W1
Whirlpool SDF6000W2
Whirlpool SDF6000W3
Whirlpool SDF6000W4
Whirlpool SDF7000W0
Whirlpool SDF7000W1
Whirlpool SDF7800W0
Whirlpool SDF7800W1
Whirlpool SDF7800W2
Whirlpool SDF7800W3
Whirlpool SDF7801W0
Whirlpool SDF8000W0
Whirlpool SDF8000W1
Maytag SDG2606AWW Dryer - Gas
Maytag SDG305DAWW Dryer - Gas
Maytag SDG3606AWQ Dryer - Gas
Maytag SDG3606AWW Dryer - Gas
Maytag SDG4000AWW Dryer - Gas
Maytag SDG405DAWW Dryer - Gas
Maytag SDG4606AWW Dryer - Gas
Maytag SDG505DAWQ Dryer - Gas
Maytag SDG505DAWW Dryer - Gas
Maytag SDG505DAXW Dryer - Gas
Maytag SDG515DAWW Dryer - Gas
Maytag SDG5401AWQ Dryer - Gas
Maytag SDG5401AWW Dryer - Gas
Maytag SDG5401AXW Dryer - Gas
Maytag SDG5701AWQ Dryer - Gas
Maytag SDG5701AWW Dryer - Gas
Maytag SDG5701AXW Dryer - Gas
Whirlpool SDH481B0
Whirlpool SDH501B20
Amana SDI22A Ref - SXS/I&W
Amana SDI22A-A Ref - SXS/I&W
Amana SDI22A-AG Ref - SXS/I&W
Amana SDI22A-C Ref - SXS/I&W
Amana SDI22B Ref - SXS/I&W
Amana SDI22B-A Ref - SXS/I&W
Amana SDI22B-C Ref - SXS/I&W
Amana SDI22B-G Ref - SXS/I&W
Amana SDI22B-L Ref - SXS/I&W
Amana SDI22C Ref - SXS/I&W
Amana SDI22C-A Ref - SXS/I&W
Amana SDI22C-C Ref - SXS/I&W
Amana SDI22C-G Ref - SXS/I&W
Amana SDI22C-L Ref - SXS/I&W
Amana SDI22D Ref - SXS/I&W
Amana SDI22E Ref - SXS/I&W
Amana SDI22E-1-A Ref - SXS/I&W
Amana SDI22E-1-C Ref - SXS/I&W
Amana SDI22E-A Ref - SXS/I&W
Amana SDI22E-C Ref - SXS/I&W
Amana SDI22E-G Ref - SXS/I&W
Amana SDI22E-L Ref - SXS/I&W
Amana SDI22E1 Ref - SXS/I&W
Amana SDI22E1G Ref - SXS/I&W
Amana SDI22E1L Ref - SXS/I&W
Amana SDI22F Ref - SXS/I&W
Amana SDI22F-1 Ref - SXS/I&W
Amana SDI22F-1-G Ref - SXS/I&W
Amana SDI22F-1-L Ref - SXS/I&W
Amana SDI22F-G Ref - SXS/I&W
Amana SDI22F-L Ref - SXS/I&W
Amana SDI22FA Ref - SXS/I&W
Amana SDI22FC Ref - SXS/I&W
Amana SDI22FG Ref - SXS/I&W
Amana SDI22FL Ref - SXS/I&W
Amana SDI22G Ref - SXS/I&W
Amana SDI22GG Ref - SXS/I&W
Amana SDI22GL Ref - SXS/I&W
Amana SDI22N Ref - SXS/I&W
Amana SDI22N-1 Ref - SXS/I&W
  #2 (permalink)
Old 04-06-2009, 06:29 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts.
Replacement parts for MAYTAG SDE405DAYW | AppliancePartsPros.com
Put the unit in air only and try it.
If it runs then you may have a grounded heater coil.
Either the heater has sagged or broken and is touching the frame.
__________________
  #3 (permalink)
Old 04-07-2009, 03:53 AM
Junior Member
Default
It looks as though it will run without tripping the breaker in the time dry/air fluff mode. How do we go about replacing the heater element? Is part # AP4294403 the correct part number?
  #4 (permalink)
Old 04-07-2009, 05:18 AM
Senior Expert
APP Volunteer
Default
Here is a service manual although it does not specifically list your unit, yours is basically the same
http://www.servicematters.com/maytag...s/16023020.pdf
Yes
I would not order anything until you confirm either visually or with a meter that this is the problem as there are other components that could cause this but the heater is at the top of the list.
Since you have to open it up I would recommend you check the following for wear and bearing slop: rear support rollers, front glides, belt, idler wheel and drum seals. You might as well give it a bit of an overhaul.
Give the interior an good clean including the blower wheel.
Also a good idea to clean and check your vent system
__________________
  #5 (permalink)
Old 04-12-2009, 06:59 PM
jgv jgv is offline
Junior Member
jgv is on a distinguished road
Default
had a dryer trip a breaker once, it was a bad roller making it hard for the motor to turn the drum if its an older dryer it might be the problem
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Trips Breaker one80two Dryer Repair 10 11-30-2009 07:59 AM
Dryer trips breaker dayeaw Dryer Repair 7 02-24-2009 03:59 PM
gas dryer trips breaker cerriel Dryer Repair 1 02-20-2009 04:33 PM
Dryer trips circuit breaker garyr1950 Dryer Repair 2 01-22-2009 04:07 AM
Dryer Trips Breaker with wet clothes msElmo Dryer Repair 3 09-09-2008 06:18 AM
