Discuss
Dryer wont heat
 in
Dryer Repair
Dryer will not give off any heat, drum turns, starts great just no heat. Please advise. Thanks! Checked the dryer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer wont heat
  #1 (permalink)
Old 08-29-2011, 04:25 PM
Junior Member
Shawn Mueller is on a distinguished road
Question Dryer wont heat
Model Number: LEN200JQ0   Brand: Whirlpool   Age: More than 10 years
Checked the dryer vent and it is clear. Could it be the heating element?
Related Models
Whirlpool LEN3434AW0 Residential Dryer
Whirlpool LEN3624BN0 ELECTRIC DRYER
Whirlpool LEN3624BN1 ELECTRIC DRYER
Whirlpool LEN3624BN2 ELECTRIC DRYER
Whirlpool LEN3624BW0 ELECTRIC DRYER
Whirlpool LEN3624BW1 ELECTRIC DRYER
Whirlpool LEN3624BW2 ELECTRIC DRYER
Whirlpool LEN3634DW0 ELECTRIC DRYER
Whirlpool LEN3634DW1 ELECTRIC DRYER
Whirlpool LEP6646AN1 ELECTRIC DRYER
Whirlpool LEP6646AN2 ELECTRIC DRYER
Whirlpool LEP6646AW0 Residential Dryer
Whirlpool LEP6646AW1 ELECTRIC DRYER
Whirlpool LEP6646AW2 ELECTRIC DRYER
Whirlpool LEP6848AN1 ELECTRIC DRYER
Whirlpool LEP6848AN2 ELECTRIC DRYER
Whirlpool LEP6848AW0 Residential Dryer
Whirlpool LEP6848AW1 ELECTRIC DRYER
Whirlpool LEP6848AW2 ELECTRIC DRYER
Whirlpool LEP7858AN1 ELECTRIC DRYER
Whirlpool LEP7858AN2 ELECTRIC DRYER
Whirlpool LEP7858AQ2 ELECTRIC DRYER
Whirlpool LEP7858AW0 Residential Dryer
Whirlpool LEP7858AW1 ELECTRIC DRYER
Whirlpool LEP7858AW2 ELECTRIC DRYER
Whirlpool LEP7858AZ2 ELECTRIC DRYER
Frigidaire LEQ1442ES0 Frigidaire/dryer
Frigidaire LEQ1442ES1 DRYER
Frigidaire LEQ1452KS0 DRYER
Frigidaire LEQ2152EE0 Frigidaire/dryer
Frigidaire LEQ2152EE1 DRYER
Frigidaire LEQ2152ES0 Frigidaire/electric Dryer
Frigidaire LEQ2152HS0 DRYER
Frigidaire LEQ332DS0 Frigidaire/dryer
Whirlpool LEQ5000KQ0 DRYER
Whirlpool LEQ5000KQ1 29"ELECTRIC DRYER
Whirlpool LEQ5000KQ2 29"ELECTRIC DRYER
Whirlpool LEQ5000KW1 29"ELECTRIC DRYER
Whirlpool LEQ5000KW2 29"ELECTRIC DRYER
Whirlpool LEQ5000PW0 29"ELECTRIC DRYER
Frigidaire LEQ6000ES0 Frigidaire/dryer
Frigidaire LEQ6000ES1 Frigidaire/dryer
Frigidaire LEQ6000ES2 Frigidaire/electric Dryer
Frigidaire LEQ6400FS0 DRYER
Frigidaire LEQ642DS0 Frigidaire/dryer
Frigidaire LEQ7000EG0 Frigidaire/dryer
Frigidaire LEQ7000ES0 Frigidaire/dryer
Frigidaire LEQ7000ES1 Frigidaire/dryer
Frigidaire LEQ7000ES2 Frigidaire/dryer
Whirlpool LEQ7000KQ0 DRYER
Whirlpool LEQ7000KQ1 DRYER
Whirlpool LEQ7000KQ2 DRYER
Whirlpool LEQ7030KQ0 DRYER
Whirlpool LEQ7030KQ1 RESIDENTIAL DRYER
Whirlpool LEQ7030KQ2 29"ELECTRIC DRYER
Frigidaire LEQ8000FE0 DRYER
Whirlpool LEQ8000HQ0 DRYER
Whirlpool LEQ8000HQ1 DRYER
Whirlpool LEQ8000JQ0 DRYER
Whirlpool LEQ8000JQ1 DRYER
Whirlpool LEQ8000JQ2 DRYER
Whirlpool LEQ8000JQ3 29"ELECTRIC DRYER
Whirlpool LEQ8000JQ4 ELECTRIC DRYER
Whirlpool LEQ8100KQ0 DRYER
Whirlpool LEQ8100KQ1 DRYER
Whirlpool LEQ8100KT0 DRYER
Whirlpool LEQ8100KT1 DRYER
Whirlpool LEQ8611LG0 RESIDENTIAL DRYER
Whirlpool LEQ8611LG1 27"ELECTRIC DRYER
Whirlpool LEQ8611LW0 RESIDENTIAL DRYER
Whirlpool LEQ8611LW1 27"ELECTRIC DRYER
Whirlpool LEQ8611PG0 27" ELECTRIC DRYER
Whirlpool LEQ8611PG1 27"ELECTRIC DRYER
Whirlpool LEQ8611PG2 27"ELECTRIC DRYER
Whirlpool LEQ8611PW0 27" ELECTRIC DRYER
Whirlpool LEQ8611PW1 27"ELECTRIC DRYER
Whirlpool LEQ8611PW2 27"ELECTRIC DRYER
Whirlpool LEQ8621PG0 27" ELECTRIC DRYER
Whirlpool LEQ8621PG1 27"ELECTRIC DRYER
Whirlpool LEQ8621PG2 27"ELECTRIC DRYER
Whirlpool LEQ8621PW0 27" ELECTRIC DRYER
Whirlpool LEQ8621PW1 27"ELECTRIC DRYER
Whirlpool LEQ8621PW2 27"ELECTRIC DRYER
Whirlpool LEQ8800JQ0 DRYER
Whirlpool LEQ8800JQ1 DRYER
Whirlpool LEQ8800JT0 DRYER
Whirlpool LEQ8800JT1 DRYER
Whirlpool LEQ8857HQ0 DRYER
Whirlpool LEQ8857HQ1 DRYER
Whirlpool LEQ8857HZ0 DRYER
Whirlpool LEQ8857HZ1 DRYER
Whirlpool LEQ8857JQ0 DRYER
Whirlpool LEQ8857JQ1 DRYER
Whirlpool LEQ8857JT0 DRYER
Whirlpool LEQ8857JT1 DRYER
Whirlpool LEQ8858HQ0 DRYER
Whirlpool LEQ8858HQ1 DRYER
Whirlpool LEQ8858HZ0 DRYER
Whirlpool LEQ8858HZ1 DRYER
Whirlpool LEQ8858JQ0 DRYER
Whirlpool LEQ8858JQ1 DRYER
Whirlpool LEQ8858JT0 DRYER
Whirlpool LEQ8858JT1 DRYER
Whirlpool LEQ8858JZ1 DRYER
Whirlpool LEQ9030PQ0 29"ELECTRIC DRYER
Whirlpool LEQ9030PQ1 29" ELECTRIC DRYER
Whirlpool LEQ9508KQ0 RESIDENTIAL DRYER
Whirlpool LEQ9508LG0 RESIDENTIAL DRYER
Whirlpool LEQ9508LW0 RESIDENTIAL DRYER
Whirlpool LEQ9508LW1 29"ELECTRIC DRYER
Whirlpool LEQ9508PG0 29"ELECTRIC DRYER
Whirlpool LEQ9508PG1 29" ELECTRIC DRYER
Whirlpool LEQ9508PW0 29"ELECTRIC DRYER
Whirlpool LEQ9508PW1 29" ELECTRIC DRYER
Whirlpool LEQ9557KQ1 RESIDENTIAL DRYER
Whirlpool LEQ9557KT1 RESIDENTIAL DRYER
Whirlpool LEQ9558KQ0 RESIDENTIAL DRYER
Whirlpool LEQ9558KQ1 RESIDENTIAL DRYER
Whirlpool LEQ9558KT0 RESIDENTIAL DRYER
Whirlpool LEQ9558KT1 RESIDENTIAL DRYER
  #2 (permalink)
Old 08-30-2011, 01:37 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Are you sure it is LEN 200 and not LEN2000.
The following is for a LEN2000JQ0
Replacement parts for WHIRLPOOL LEN2000JQ0 ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
Yes it could be the heating element.
First I would check power to the unit. The motor and timer run off of 120 volts (L1 to Neutral) but the heating element requires the full 240 volts (L1 to L2)
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If OK unplug the unit and check the heating element.
If it is OK check the thermal cut-off (Item 9 in Section 3).
If this is blown get back to us as there are other things you should check before replacing.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
  #3 (permalink)
Old 09-08-2011, 04:11 PM
Junior Member
Default thermal cut off has no continuity
I checked the breakers all is good. I checked the continuity of the thermal cut off and there is none. What would cause this to blow out? The thermosat on the heating element is good.
  #4 (permalink)
Old 09-08-2011, 04:14 PM
Junior Member
Default Dryer won't heat
I checked the breakers and all is good. I did a continuity check on the thermal cut off and it is blown. What would cause this ? The thermosat on the heating element is good.
  #5 (permalink)
Old 09-08-2011, 06:18 PM
Senior Expert
APP Volunteer
Default
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 8 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
__________________
  #6 (permalink)
Old 09-15-2011, 09:03 PM
Junior Member
Default Dryer still won't heat
I checked all the volts from the outlet, to the machine all is good. Installed new heating element. I had no ohm reading on the thermal cut off so I changed it. Turned on the dryer and it kept tripping the breaker, then after three trys the thermal cut off blew. So now I ordered and replaced a new thermal cut off, with the high limit and the dryer cycle thermosat. I turned on the dryer and within a second it tripped the breaker. I won't try it again because the stats are still reading 0 ohms and I don't want to wreck the new parts Thermal fuse has 0 ohms. The ohms on the heating element are 0, shouldn't this be higher? The dryer cycle has 0 ohms at the red wires and 3 ohms at the purple wires, is this right? When I put in the bad thermal cut off back in, I can turn the dryer on and run it with out tripping the breaker. Totally confused, please help.
  #7 (permalink)
Old 09-16-2011, 01:11 AM
Senior Expert
APP Volunteer
Default
Yes it should be between 8 to 12 ohms. Be sure to use the most sensitive ohms scale on your meter usually 200 ohms. See my earlier posts.
I cannot comment on this as I am not sure where you are measuring.
Sounds like you have a short somewhere in the heater circuit.
Did you check the heating coil before installing it?
I would recheck it as it may be grounded, see my earlier post.
It is always a good idea to check parts before installing them as sometimes they are no good direct from the manufacturer.
It should not be that difficult to find out what is causing this as it happens all the time.
I also would not replace any more parts unit you find the cause.
__________________
  #8 (permalink)
Old 09-16-2011, 01:13 AM
Senior Expert
APP Volunteer
Default
The site double posted the above reply for some reason so I just edited this one out.
__________________
  #9 (permalink)
Old 09-28-2011, 08:26 PM
Junior Member
msteinson is on a distinguished road
Default
Does anyone know if this was ever solved? I have exactly the same problem and I don't want to burn out another cutoff switch. I'm pretty sure that i don't have a short on the heating coil.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer still wont hold heat and timer wont work patricktk0 Dryer Repair 4 04-19-2011 06:10 AM
gas dryer wont heat Brian33 Dryer Repair 0 09-29-2009 02:26 PM
clothes dryer wont heat timer wont work tampee Dryer Repair 2 01-17-2009 09:53 AM
my dryer wont heat erica2008 Oven Repair (including Ranges and Cooktops) 1 12-05-2008 03:20 PM
Timer wont advance and dryer wont heat awatt26 Dryer Repair 2 06-20-2008 09:43 PM
