Discuss
Dryer won't start, light is out, but I hear the timer.
 in
Dryer Repair
My dryer was working fine yesterday, but today I put a load in and pushed the button it wouldn't
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't start, light is out, but I hear the timer.
  #1 (permalink)
Old 11-27-2007, 09:08 AM
GeorgiaV GeorgiaV is offline
Junior Member
GeorgiaV is on a distinguished road
Unhappy Dryer won't start, light is out, but I hear the timer.
Model Number: LNC7753A71   Brand: Admiral   Age: More than 10 years
My dryer was working fine yesterday, but today I put a load in and pushed the button it wouldn't start and the light went out. I still hear the timer. I checked the breakers, no problem there. Please help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-27-2007, 11:04 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is the connection of the power cord to the dryer for burned wires.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-27-2007, 12:41 PM
Junior Member
Default
Checked the wires from the dryer and at the wall, looks good.
  #4 (permalink)
Old 11-27-2007, 01:18 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
i don,t know how old this dryer is, but I would check the door switch and lever behind the door,make sure it makes a clicking sound . Then check [if it,s a old dryer]the belt, if the belt breakes the idler pulley drops down an hit,s a belt kill switch, this will stop the motor. Try that after you check the voltage.
__________________
  #5 (permalink)
Old 11-27-2007, 06:11 PM
Junior Member
Default
It is a very old dryer. Voltage checks out and it is getting electricity to dryer. The switch behind the door does not make a clicking sound. I pulled the top off to check the switch behind the door and it is getting electricity to it. The belt appears intact. I did not feel any tears, areas of wear or nicks.
  #6 (permalink)
Old 11-28-2007, 01:04 PM
Senior Expert
APP Volunteer
Default
check to see if the door switch has continuity. It should click.
__________________
  #7 (permalink)
Old 11-28-2007, 07:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I've tried to find the wiring diagram for your dryer and I could not.
It is very hard to diagnose the problem without the wiring diagram, but the first thing I would check is the thermal fuse and the hi limit thermostat.
Check them for continuity and replace if any one is open.
When you buy the thermal fuse, it comes as a kit, consists the thermal fuse and the hi limit thermostat.
The thermal fuse kit
- The part number for the thermal fuse kit AP415996
P.S. If you have the wiring diagram and can post it, it may help.
__________________
  #8 (permalink)
Old 11-28-2007, 08:05 PM
Junior Member
Default
I do have the wiring diagram and will scan and post in the morning. Thank you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Timer Wire problem deleriousone Dryer Repair 17 08-06-2008 02:21 PM
washer doesnt spin all i hear is buzzing and the smell of smoke willp3 Washer Repair 5 11-03-2007 03:23 PM
Light comes on, timer clicks, drum does not turn. bradleyque Dryer Repair 1 10-12-2007 03:22 AM
I can hear water behind the drum is this normal? repowoman Washer Repair 0 10-06-2007 01:58 PM
crosley shelvador fridge not freezing or cooling hear clicking noise noddef2000 Refrigerator & Freezer Repair 3 08-27-2007 09:11 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
