Discuss
Maytag Neptune dryer won’t stay off
 in
Dryer Repair
Our Maytag Neptune dryer stopped working - the panel stayed on and would make a beep every few minutes but
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Neptune dryer won’t stay off
  #1 (permalink)
Old 08-24-2011, 06:36 AM
Junior Member
atwmd is on a distinguished road
Default Maytag Neptune dryer won’t stay off
Model Number: MDE5500AYQ   Brand: Maytag   Age: 5 - 10 years
Our Maytag Neptune dryer stopped working - the panel stayed on and would make a beep every few minutes but the dryer would not run. Just stayed on making the beep. A repair man told us we needed a new control board. We purchased one from Appliance Parts Pros and installed it last night. We were thrilled when it worked - but after the first load dried and I turned the dryer off, within minutes it turned itself back on to 44 minutes and would beep every few seconds. I turned it off, it turned itself back on. So I have unplugged it now. It will run when I hit “pause” but after the cycle is over - it won’t stay off.
Anyone have any ideas?
Thanks in advance
Ads By Google
Related Models
Maytag MDE5500AYQ Dryer - Ele
Maytag MDE5500AYW Dryer - Ele
Maytag MDE5500AZQ Dryer - Ele
Maytag MDE5500AZW Dryer - Ele
Maytag MDE5806AYK Dryer - Ele
Maytag MDE5806AYW Dryer - Ele
Maytag MDE5806AZK Dryer - Ele
Maytag MDE5806AZW Dryer - Ele
Maytag MDE5960AYW Dryer - Ele
Maytag MDE6000AUW Dryer - Ele
Maytag MDE6000AYQ Dryer - Ele
Maytag MDE6000AYW Dryer - Ele
Maytag MDE6000AZQ Dryer - Ele
Maytag MDE6000AZW Dryer - Ele
Maytag MDE6200AYQ Dryer - Ele
Maytag MDE6200AYW Dryer - Ele
Maytag MDE6200AZQ Dryer - Ele
Maytag MDE6200AZW Dryer - Ele
Maytag MDE6400AGW Dryer - Ele
Maytag MDE6400AYQ Dryer - Ele
Maytag MDE6400AYW Dryer - Ele
Maytag MDE6400AZW Dryer - Ele
Maytag MDE6460AYW Dryer - Ele
Maytag MDE6460AZW Dryer - Ele
Maytag MDE6657BYQ Dryer - Ele
Maytag MDE6657BYW Dryer - Ele
Maytag MDE6700AYW Dryer - Ele
Maytag MDE6700AZW Dryer - Ele
Maytag MDE6800AYB Dryer - Ele
Maytag MDE6800AYQ Dryer - Ele
Maytag MDE6800AYW Dryer - Ele
Maytag MDE6800AZQ Dryer - Ele
Maytag MDE6800AZW Dryer - Ele
Maytag MDE7057AYQ Dryer - Ele
Maytag MDE7057AYW Dryer - Ele
Maytag MDE7057AZW Dryer - Ele
Maytag MDE7400AYQ Dryer - Ele
Maytag MDE7400AYW Dryer - Ele
Maytag MDE7400AZQ Dryer - Ele
Maytag MDE7400AZW Dryer - Ele
Maytag MDE7460AYQ Dryer - Ele
Maytag MDE7460AYW Dryer - Ele
Maytag MDE7500AYQ Dryer - Ele
Maytag MDE7500AYW Dryer - Ele
Maytag MDE7500AZQ Dryer - Ele
Maytag MDE7500AZW Dryer - Ele
Maytag MDE7550AGW Dryer - Ele
International MDE7550AGW Dryer - Ele
Maytag MDE7600AUW Dryer - Ele
Maytag MDE7600AYQ Dryer - Ele
Maytag MDE7600AYW Dryer - Ele
Maytag MDE7600AZQ Dryer - Ele
Maytag MDE7600AZW Dryer - Ele
Maytag MDE7657AYQ Dryer - Ele
Maytag MDE7657AYW Dryer - Ele
Maytag MDE7657BYQ Dryer - Ele
Maytag MDE7657BYW Dryer - Ele
Maytag MDE7658AYQ Dryer - Ele
Maytag MDE7658AYW Dryer - Ele
Maytag MDE7658BYQ Dryer - Ele
Maytag MDE7658BYW Dryer - Ele
Maytag MDE7757AYQ Dryer - Ele
Maytag MDE7757AYW Dryer - Ele
Maytag MDE7758AYQ Dryer - Ele
Maytag MDE7758AYW Dryer - Ele
Maytag MDE8000AYQ Dryer - Ele
Maytag MDE8000AYW Dryer - Ele
Maytag MDE8000AZW Dryer - Ele
Maytag MDE8057AYQ Dryer - Ele
Maytag MDE8057AYW Dryer - Ele
Maytag MDE8057AZW Dryer - Ele
Maytag MDE8058AYQ Dryer - Ele
Maytag MDE8058AYW Dryer - Ele
Maytag MDE8400AYQ Dryer - Ele
Maytag MDE8400AYW Dryer - Ele
Maytag MDE8400AZW Dryer - Ele
Maytag MDE8416AYA Dryer - Ele
Maytag MDE8416AYW Dryer - Ele
International MDE8426AAW Dryer - Ele
International MDE8426AGW Dryer - Ele
Maytag MDE8500AYW Dryer - Ele
Maytag MDE8506AYA Dryer - Ele
Maytag MDE8506AYW Dryer - Ele
Maytag MDE8506AZW Dryer - Ele
International MDE8550AGW Dryer - Ele
International MDE8550BGW Dryer - Ele
Maytag MDE8600AYQ Dryer - Ele
Maytag MDE8600AYW Dryer - Ele
Maytag MDE8600AZQ Dryer - Ele
Maytag MDE8600AZW Dryer - Ele
Maytag MDE8757AYQ Dryer - Ele
Maytag MDE8757AYW Dryer - Ele
Maytag MDE9206AYA Dryer - Ele
Maytag MDE9206AYW Dryer - Ele
Maytag MDE9206AZW Dryer - Ele
Maytag MDE9306AUW Dryer - Ele
Maytag MDE9306AYA Dryer - Ele
Maytag MDE9306AYW Dryer - Ele
Maytag MDE9306AZA Dryer - Ele
Maytag MDE9306AZW Dryer - Ele
Maytag MDE9316AYA Dryer - Ele
Maytag MDE9316AYQ Dryer - Ele
Maytag MDE9316AYW Dryer - Ele
Maytag MDE9316AZW Dryer - Ele
Maytag MDE9357AYA Dryer - Ele
Maytag MDE9357AYQ Dryer - Ele
Maytag MDE9357AYW Dryer - Ele
Maytag MDE9360AYW Dryer - Ele
Maytag MDE9390AYW Dryer - Ele
Maytag MDE9390AZW Dryer - Ele
Maytag MDE9420AYW Dryer - Ele
Maytag MDE9420AZW Dryer - Ele
Maytag MDE9520AYQ Dryer - Ele
Maytag MDE9520AYW Dryer - Ele
Maytag MDE9520AZW Dryer - Ele
Maytag MDE9557AYA Dryer - Ele
Maytag MDE9557AYQ Dryer - Ele
Maytag MDE9557AYW Dryer - Ele
Maytag MDE9557AZA Dryer - Ele
Maytag MDE9557AZQ Dryer - Ele
  #2 (permalink)
Old 08-24-2011, 07:01 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
It sounds like you may have a stuck or shorted membrane (Touch Pad) switch. Did your technician test the touch pad?
  #3 (permalink)
Old 08-24-2011, 07:15 AM
Junior Member
Default
How do you test the membrane or touchpad switch?
  #4 (permalink)
Old 08-24-2011, 07:35 AM
Senior Expert
APP Volunteer
Default
You have to find the common connection in the ribbon connector, and as you press each "key" in the membrane, test its corresponding terminal (In the ribbon connector) for continuity. It isn't easy to do this, because of the close proximity of al the terminals. They're the bare copper ends you see at the end of the ribbon, when you disconnect it rom the circuit board. You can do it, but it does take a bit of patience.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Gas Dryer Does Not Stay On JP2253 Dryer Repair 0 12-18-2010 09:06 AM
Maytag Neptune dryer Ncktaylor78 Dryer Repair 3 11-26-2010 07:20 PM
Neptune FL Gas Dryer-Heat will not stay on mjzess Dryer Repair 1 06-17-2010 11:46 AM
Maytag Neptune gas dyer does not stay hot squarecookie Dryer Repair 4 04-20-2009 04:39 AM
How to take apart Maytag Neptune Dryer blbette Dryer Repair 1 12-22-2008 05:04 PM
