Discuss
bad drum felt seal(s) Front and back
 in
Dryer Repair
The Whirlpool Gas Dryer CG2951XSN2, ICX3414556 does not dry the heavy materials like jeans completly. How do I check for
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » bad drum felt seal(s) Front and back
  #1 (permalink)
Old 11-26-2007, 02:23 PM
Junior Member
glenn1 is on a distinguished road
Default bad drum felt seal(s) Front and back
Model Number: CG2951XSN2   Brand: Whirlpool   Age: More than 10 years
The Whirlpool Gas Dryer CG2951XSN2, ICX3414556 does not dry the heavy materials like jeans completly. How do I check for the temperature of the dryer reaches 125 degrees or more ? The venting leading outside is OK. I changed thermal fuse #2986 and Gas valve solenoid coil kit #3479. Do you think I have a bad drum felt seal ? I do not see this model number on the web site.
Ads By Google
Related Models
Whirlpool CG2951XSW0
Whirlpool CG2951XSW1
Whirlpool CG2951XSW2
Whirlpool CG2951XSW3
Whirlpool CG2951XYG0
Whirlpool CG2951XYG1
Whirlpool CG2951XYG2
Whirlpool CG2951XYG3
Whirlpool CG2951XYN0
Whirlpool CG2951XYN1
Whirlpool CG2951XYN2
Whirlpool CG2951XYN3
Whirlpool CG2951XYW0
Whirlpool CG2951XYW1
Whirlpool CG2951XYW2
Whirlpool CG2951XYW3
Whirlpool CG2951XYW4
Thermador CG29E
Thermador CG29F
Thermador CG29FLP
Frigidaire CG300SP2D1 Frg(v2) / Gas Range
Frigidaire CG300SP2D2 Frg(v2) / Gas Range
Frigidaire CG300SP2D3 Frg(v2) / Gas Range
Frigidaire CG300SP2D5 Frg(v4) / Gas Range
Frigidaire CG300SP2W1 Tap(v4) / Gas Range
Frigidaire CG300SP2W2 Frg(v1) / Gas Range
Frigidaire CG300SP2W3 Frg(v1) / Gas Range
Frigidaire CG300SP2W5 Frg(v3) / Gas Range
Frigidaire CG300SP2WD01 Kel(v14) / Gas Range
Frigidaire CG300SP2WH01 Frg(v3) / Gas Range
Frigidaire CG300SP2WJ01 Kel(v15) / Gas Range
Frigidaire CG300SP2WL01 Frg(v2) / Gas Range
Frigidaire CG300SP2WW01 Frg(v1) / Gas Range
Frigidaire CG300SP2WY01 Gib(v9) / Gas Range
Frigidaire CG300SP2Y1 Frg(v3) / Gas Range
Frigidaire CG301SP2D03 Frg(v4) / Gas Range
Frigidaire CG301SP2D1 Frg(v2) / Gas Range
Frigidaire CG301SP2D2 Frg(v2) / Gas Range
Frigidaire CG301SP2D4 Frg(v2) / Gas Range
Frigidaire CG301SP2W1 Tap(v4) / Gas Range
Frigidaire CG301SP2W2 Frg(v1) / Gas Range
Frigidaire CG301SP2W3 Frg(v3) / Gas Range
Frigidaire CG301SP2W4 Frg(v1) / Gas Range
Frigidaire CG301SP2WD01 Kel(v14) / Gas Range
Frigidaire CG301SP2WH01 Frg(v3) / Gas Range
Frigidaire CG301SP2WJ01 Kel(v15) / Gas Range
Frigidaire CG301SP2WL01 Frg(v2) / Gas Range
Frigidaire CG301SP2WW01 Frg(v1) / Gas Range
Frigidaire CG301SP2WY01 Gib(v9) / Gas Range
Frigidaire CG301SP2Y1 Frg(v3) / Gas Range
Crosley CG3100PPA Range - F/s Std Gas
Crosley CG3100PPW Range - F/s Std Gas
Crosley CG3110PPA Range - F/s Std Gas
Crosley CG3110PPW Range - F/s Std Gas
Crosley CG3110PRA Range - F/s Std Gas
Crosley CG3110PRV Range - F/s Std Gas
Crosley CG3110PRW Range - F/s Std Gas
Crosley CG31200ADQ Range - F/s Std Gas
Crosley CG31200ADV Range - F/s Std Gas
Crosley CG31200ADW Range - F/s Std Gas
Crosley CG31200BDQ Range - F/s Std Gas
Crosley CG31200BDV Range - F/s Std Gas
Crosley CG31200BDW Range - F/s Std Gas
Crosley CG3120SPA Range - F/s Std Gas
Crosley CG3120SPN Range - F/s Std Gas
Crosley CG3120SPW Range - F/s Std Gas
Crosley CG3120SRA Range - F/s Std Gas
Crosley CG3120SRW Range - F/s Std Gas
Crosley CG3131WRA Range - F/s Std Gas
Crosley CG3131WRW Range - F/s Std Gas
Crosley CG3131WUA Range - F/s Std Gas
Crosley CG3131WUW Range - F/s Std Gas
Crosley CG3131XRA Range - F/s Std Gas
Crosley CG3131XRW Range - F/s Std Gas
Crosley CG3131XUA Range - F/s Std Gas
Crosley CG3131XUW Range - F/s Std Gas
Crosley CG3137XUA Range - F/s Std Gas
Crosley CG3137XUW Range - F/s Std Gas
Crosley CG31400ADW Range - F/s Std Gas
Crosley CG31600ADB Range - F/s Std Gas
Crosley CG31600ADQ Range - F/s Std Gas
Crosley CG31600ADV Range - F/s Std Gas
Crosley CG3177VRV Range - F/s Std Gas
Crosley CG3177VUV Range - F/s Std Gas
Crosley CG3177XRA Range - F/s Std Gas
Crosley CG3177XRW Range - F/s Std Gas
Crosley CG3177XUA Range - F/s Std Gas
Crosley CG3177XUW Range - F/s Std Gas
Crosley CG3231XRA Range - F/s Cont Clean Gas
Crosley CG3231XRW Range - F/s Cont Clean Gas
Crosley CG3231XUA Range - F/s Cont Clean Gas
Crosley CG3231XUW Range - F/s Cont Clean Gas
Crosley CG34300ADA Range - S/c F/s Gas
Crosley CG34300ADT Range - S/c F/s Gas
Crosley CG34300ADW Range - S/c F/s Gas
Crosley CG3432SRA Range - S/c F/s Gas
Crosley CG3432SRW Range - S/c F/s Gas
Crosley CG3432XRA Range - S/c F/s Gas
Crosley CG3432XRW Range - S/c F/s Gas
Crosley CG3438SRA Range - S/c F/s Gas
Crosley CG3438SRW Range - S/c F/s Gas
Crosley CG34700ADD Range - S/c F/s Gas
Crosley CG34700ADQ Range - S/c F/s Gas
Crosley CG34700ADV Range - S/c F/s Gas
Crosley CG34700BDQ Range - S/c F/s Gas
Crosley CG34700BDT Range - S/c F/s Gas
Crosley CG34700BDV Range - S/c F/s Gas
Crosley CG34700BDW Range - S/c F/s Gas
Crosley CG3478VVD Range - S/c F/s Gas
Crosley CG3478VVV Range - S/c F/s Gas
Crosley CG3478XRA Range - S/c F/s Gas
Crosley CG3478XRW Range - S/c F/s Gas
Crosley CG3478XVA Range - S/c F/s Gas
Crosley CG3478XVW Range - S/c F/s Gas
Crosley CG34800ADQ Range - F/s Std Gas
Crosley CG34800ADS Range - F/s Std Gas
Crosley CG34800ADT Range - F/s Std Gas
Crosley CG34800ADV Range - F/s Std Gas
Crosley CG34800ADW Range - F/s Std Gas
Crosley CG34800BDS Range - S/c F/s Gas
  #2 (permalink)
Old 11-26-2007, 03:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would check is condition of the blower wheel (#10 on the bulkhead break down diagram) and the chute (#1 on the same break down diagram) on the back of the dryer.
It should be "W" instead of "N" in the model number.
- Here are the break down diagrams for the Whirlpool dryer Model CG2951XSW2
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool rear drum felt seal rhanauer Dryer Repair 3 10-13-2009 06:42 PM
Felt belt on back of drum rainey Dryer Repair 0 09-30-2009 05:15 AM
rear drum felt seal allthewrights Dryer Repair 1 08-01-2009 05:14 PM
dryer drum front felt seal mashed, temperature control problem stansadin Dryer Repair 3 07-19-2009 06:54 AM
GE Dryer Felt Drum Seal johngambill Dryer Repair 1 04-02-2009 02:58 PM
