Discuss
bad drum felt seal(s) Front and back
 in
Dryer Repair
The Whirlpool Gas Dryer CG2951XSN2, ICX3414556 does not dry the heavy materials like jeans completly. How do I check for
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » bad drum felt seal(s) Front and back
  #1 (permalink)
Old 11-26-2007, 03:23 PM
glenn1 glenn1 is offline
Junior Member
glenn1 is on a distinguished road
Default bad drum felt seal(s) Front and back
Model Number: CG2951XSN2   Brand: Whirlpool   Age: More than 10 years
The Whirlpool Gas Dryer CG2951XSN2, ICX3414556 does not dry the heavy materials like jeans completly. How do I check for the temperature of the dryer reaches 125 degrees or more ? The venting leading outside is OK. I changed thermal fuse #2986 and Gas valve solenoid coil kit #3479. Do you think I have a bad drum felt seal ? I do not see this model number on the web site.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-26-2007, 04:43 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is condition of the blower wheel (#10 on the bulkhead break down diagram) and the chute (#1 on the same break down diagram) on the back of the dryer.
It should be "W" instead of "N" in the model number.
- Here are the break down diagrams for the Whirlpool dryer Model CG2951XSW2
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
front seal bellow on WPL Duet MGARRETT278 Washer Repair 2 04-01-2008 05:16 PM
GE Front Drum Bearing cassie31899 Dryer Repair 3 11-02-2007 12:14 PM
How to replace front seal on Kenmore washer gwalia Washer Repair 1 09-09-2007 11:45 PM
cannot put drum belt back on tight frank Dryer Repair 1 08-10-2007 09:37 PM
dryer felt seal Betty Roth Dryer Repair 0 07-25-2007 07:18 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
