AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer only heats up sometimes... Getting worse
Hello. I have one of the Frigidaire stack able washer dryers. It came with the home we bought. As of late it has been slowly taking longer to dry the cloths and now finally it wont dry them at all. I checked for heat and there was none. Then we tried it again later on and there was some. Then none again. It keeps going and coming. One day it works and then the next nothing. But it has been progressively getting worse and not working more often then working.
I took my voltmeter out and tested the tstat and limiter. Both were fine.
What else could it be? What else could I test? If it heated up fine yesterday and not today could it be the heating element?
Please advise.
Dryer Repair
