dryer no longer heating but otherwise seems ok
Originally Posted by: hrobbauman dryer no longer heating but otherwise seems ok Hrob, Check and make sure the breakers are set and locked in place and you have 240 VAC at the dryer terminal block, on the back of the dryer. Remove the front lower access panel and visually inspect the wiring for damage, remove the element assembly from the burner assembly and also check it for breaks and shorts and damage as well. From there we'll need a meter to test circuits at the control board. Good Luck, :) :) :)
