Here are your parts includes a wiring diagram.
Replacement parts for FRIGIDAIRE FDEB34RGS1 Frg(v0) / Free Standing Dryer | AppliancePartsPros.comHere is a better copy of the wiring diagram but it is for a RGS2 not a 1.
I think it is the same.
http://manuals.frigidaire.com/p...df/Webster/131953900.pdfI doubt you need a motor.
I would start by checking the thermal limiter, Item 36 in Section 1.
It should be o ohms at room temperature.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal limiter blows.
Just in case it is not a grounded element.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system, this is often the cause.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
Also this unit uses a center drum bearing which can often cause squealing so check that for wear. If OK clean out the old grease and use a high temperature grease to re-lube it. Be careful with the ball bearing (Item 5 in Section 1) once released it likes to take off and play hide and seek.
The above is just a suggestion since you have the unit opened up already.
You probably did this when you replaced the belt but I thought it was still worth mentioning.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
