the original problem began with a stripped screw on terminal block caused abig spark replaced the terminal block the control board the motor the thermister still nothing all the lights work but nothing happens you suggested testing thermal fuse it tests good dont know what to check next the motor did get dmged im pretty sure the points looked burnt
I would check the door switch to be sure that the NO (normally open) to Com (common) are closing when the door is closed. |
THIS FORUM IS DEAD!!!!!!! |
not sure how to check door switch ,when it is shut and you turn on control it siginals drying on the control knob could the switch still be bad?
