how can i tell if limit switch is good?limit has four spade connectors two of them show continuity but the other two dont is it still good?
Here are your parts includes a wiring diagram. Replacement parts for ADMIRAL LNC7764A71 DRYER- ELE | AppliancePartsPros.comI think you are confusing the hi-limit with the cycling thermostat. The hi-limit is Item 3 in Section 4. It should measure 0 ohms and only has 2 connectors. The cycling thermostat has 4 connectors. 2 are the contacts, should measure 0 ohms. The other 2 are the internal heater, should measure around 7,000 ohms,. May be measuring open because you are using too low of a meter scale, |
THIS FORUM IS DEAD!!!!!!! |
