| » Dryer Repair |
Model Number: LCN 7764A71 Brand: Admiral Age: 1 - 5 years
My admiral Dryer stopped mid cycle and there is no response the timer is still ticking but the internal light doesn't come on when door is open and i have proper voltage into and leaving timer and at the door switch it ohms out as good also, is ther a fuse or switch in line somewhere on this model if so where would it be located. Thanks for any helpful info
Tony, your dryer model is LNC7764A71, not LCN. Direct link to breakdown diagrams and parts for Model LNC7764A71.
Check the thermal fuse for continuity (unplug the dryer power cord first!). This is an electric dryer, so it needs 220 volts to operate. You would only have 110 volts at the timer or at the door switch. There are two dryer circuit breakers inside the house subpanel. They're side by side and are hopefully marked as "dryer". One of them might be tripped. Reset both breakers. If you know how to use a voltmeter, make sure there is 220 volts at the dryer wall socket. - Wiring diagram for LNC7764A71 Thermal fuse now comes as a kit which includes the hi-limit thermostat. Replace the fuse (as well as the hi-limit thermostat) if it shows no continuity. - Thermostat/Thermal fuse kit (instructions included) Hope this helps.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Thanks for the info about my dryer i did find the thermal fuse link to be bad meaning no continuity it took about 30 minutes to get the dryer apart to find it because there was no detail drawing on its location but it was mounted to the heater element box that is behind the drum. So the part is on order and we should be up and running soon. Thanks again
Good to hear that, Tony. We'll get that fuse to you in no time.
__________________
| Display Modes | |
| roper dryer repair | thecyclo | Dryer Repair | 7 | 01-27-2008 03:06 PM |
| Kenmore Dryer Repair | rvanetten | Dryer Repair | 1 | 11-07-2007 03:08 PM |
| Question for dryer repair | svaughan | Dryer Repair | 1 | 09-19-2007 08:14 PM |
| Removing dryer cabinet to repair igniter | Mikeofba | Dryer Repair | 1 | 07-27-2007 11:48 PM |
| Dryer repair | Doitmyself | Dryer Repair | 2 | 07-27-2007 02:13 PM |
