Discuss
New flame sensor failure?
 in
Dryer Repair
This dryer ran with no heat and no ignitor glow when I received it. The flame sensor showed no continuity,
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » New flame sensor failure?
  #1 (permalink)
Old 04-01-2009, 07:54 AM
Junior Member
spiderberg is on a distinguished road
Default New flame sensor failure?
Model Number: LGB6000KQ1   Brand: Whirlpool   Age: 5 - 10 years
This dryer ran with no heat and no ignitor glow when I received it. The flame sensor showed no continuity, so I replaced it and the dryer ran perfectly for only a week.
Now the ignitor warms up and glows continuously for as long as I let the dryer run, but the gas valve never opens. The new flame sensor still shows continuity, but I'm guessing that doesn't guarantee it's working properly. Is there anything other than the flame sensor that can cause this?
Ads By Google
Related Models
Whirlpool LGB6000KQ1
Whirlpool LGB6000KQ2 29"gas Dryer
Whirlpool LGB6000PQ0 29" Gas Dryer
Whirlpool LGB6000PQ1 29" Gas Dryer
General Electric LGB600GET1BC Gas range
General Electric LGB600GET2BC Gas range
General Electric LGB600GET3BC Gas range
General Electric LGB600GET4BC Gas range
Whirlpool LGB6200KQ0
Whirlpool LGB6200KQ1
Whirlpool LGB6200PQ0 29"gas Dryer
Whirlpool LGB6200PQ1 29"gas Dryer
Whirlpool LGB6300LW0
Whirlpool LGB6300LW1 29"gas Dryer
Whirlpool LGB6300PW0 29"gas Dryer
Whirlpool LGB6300PW1 29"gas Dryer
Whirlpool LGB64000LW0
Whirlpool LGB6400KQ0
Whirlpool LGB6400KQ1
Whirlpool LGB6400LW0
Whirlpool LGB6400LW1 29"gas Dryer
Admiral LGC1330ADB Surface Unit - Gas
Admiral LGC1330ADC Surface Unit - Gas
Admiral LGC1330ADW Surface Unit - Gas
Amana LGC20AW Dryer - Gas
Whirlpool LGC5000PQ0 29" Gas Dryer
Whirlpool LGC5000PQ1 29" Gas Dryer
Amana LGC50AW Dryer - Gas
Whirlpool LGC6646AN0
Whirlpool LGC6646AN1
Whirlpool LGC6646AN2
Whirlpool LGC6646AQ0
Whirlpool LGC6646AQ1
Whirlpool LGC6646AQ2
Whirlpool LGC6646AW0
Whirlpool LGC6646AW1
Whirlpool LGC6646AW2
Whirlpool LGC6646AZ0
Whirlpool LGC6646AZ1
Whirlpool LGC6646AZ2
Whirlpool LGC6848AN0
Whirlpool LGC6848AN1
Whirlpool LGC6848AN2
Whirlpool LGC6848AN3
Whirlpool LGC6848AQ0
Whirlpool LGC6848AQ1
Whirlpool LGC6848AQ2
Whirlpool LGC6848AQ3
Whirlpool LGC6848AW0
Whirlpool LGC6848AW1
Whirlpool LGC6848AW2
Whirlpool LGC6848AW3
Whirlpool LGC6848AZ0
Whirlpool LGC6848AZ1
Whirlpool LGC6848AZ2
Whirlpool LGC6848AZ3
Whirlpool LGC7646DQ0
Whirlpool LGC7646DQ1
Whirlpool LGC7646DZ0
Whirlpool LGC7646DZ1
Whirlpool LGC7848DQ0
Whirlpool LGC7848DQ1
Whirlpool LGC7848DZ0
Whirlpool LGC7848DZ1
Whirlpool LGC7858AN0
Whirlpool LGC7858AN1
Whirlpool LGC7858AN2
Whirlpool LGC7858AQ0
Whirlpool LGC7858AQ1
Whirlpool LGC7858AQ2
Whirlpool LGC7858AW0
Whirlpool LGC7858AW1
Whirlpool LGC7858AW2
Whirlpool LGC7858AZ0
Whirlpool LGC7858AZ1
Whirlpool LGC7858AZ2
Whirlpool LGC8858DQ0
Whirlpool LGC8858DQ1
Whirlpool LGC8858DZ0
Whirlpool LGC8858DZ1
Whirlpool LGC8858EQ0
Whirlpool LGC8858EQ1
Whirlpool LGC8858EQ2
Whirlpool LGC8858EQ3
Whirlpool LGC8858EZ0
Whirlpool LGC8858EZ1
Whirlpool LGC8858EZ2
Whirlpool LGC8858EZ3
Whirlpool LGC9000PW0 29" Gas Dryer
Whirlpool LGC9000PW1 29" Gas Dryer
Amana LGD20AW Dryer - Gas
Amana LGD251 Dryer - Gas
Amana LGD312 Dryer - Gas
Amana LGD32AW Dryer - Gas
Amana LGD451 Dryer - Gas
Amana LGD512 Dryer - Gas
Amana LGD57AW Dryer - Gas
Amana LGD65AW Dryer - Gas
Amana LGD851 Dryer - Gas
Amana LGD912 Dryer - Gas
Amana LGD951 Washer - Top Loading
Whirlpool LGE9848BQ1
Whirlpool LGE9848BQ2
Whirlpool LGE9848BZ1
Whirlpool LGE9848BZ2
Whirlpool LGL7646EQ0
Whirlpool LGL8858DQ0
Whirlpool LGL8858DZ0
Whirlpool LGL8858EQ0
Whirlpool LGL8858EQ1
Whirlpool LGL8858EQ2
Whirlpool LGL8858EQ3
Amana LGM439L Dryer - Gas
  #2 (permalink)
Old 04-01-2009, 11:35 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The flame sensor is actually a temperature switch which senses the igniter temperature and switches the power from the igniter to the gas valve coils to open the gas to the burner. According to your description the flame sensor you installed does not work properly. You have to talk to people who sold it to you and they have to exchange it under the part warranty.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 04-01-2009, 12:07 PM
Junior Member
Default
Thanks for the reply.
The flame sensor is actually from appliancepartspros, but I'm having doubts now about it being an issue, because I get the exact same behavior if I pull a wire off and leave it completely open. The ignitor still glows nonstop.
The wiring diagram for the dryer shows the flame sensor and two valve coils connected in parallel, and the main coil is reading zero resistance when I test it. If that coil is toast, is it possible that it's bypassing everything else?
  #4 (permalink)
Old 04-01-2009, 12:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If the coil is shorted then this is the culprit. No doubt about it.
__________________
  #5 (permalink)
Old 04-01-2009, 02:04 PM
Junior Member
Default
Just to confirm it, the ignitor does turn off at the correct time when I run it with the main coil disconnected. I'll be sure to update when the replacement is in.
Update - back up and running with a new main coil. Thanks again for the help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
flame sensor Bob P Dryer Repair 0 01-19-2010 03:59 PM
Sensor Failure Maytag2075 Washer Repair 3 12-19-2009 12:55 PM
flame sensor lnarvaez Oven Repair (including Ranges and Cooktops) 0 09-12-2009 12:15 PM
Flame sensor redrwut Dryer Repair 4 02-21-2009 03:21 PM
flame sensor sarrah76 Dryer Repair 1 01-10-2009 05:38 AM
