Discuss
no heat at all
 in
Dryer Repair
no heat at all. Replaced the heating element. still no heat. i checked voltage on all thermostat's and found 117.00
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » no heat at all
  #1 (permalink)
Old 08-14-2011, 12:23 PM
Junior Member
75Transam is on a distinguished road
Thumbs down no heat at all
Model Number: ler7646eq2   Brand: Whirlpool   Age: 5 - 10 years
no heat at all. Replaced the heating element. still no heat. i checked voltage on all thermostat's and found 117.00 on all. can u direct me in what to check.
Ads By Google
Related Models
Whirlpool LER7646EQ2
Whirlpool LER7646EZ0
Whirlpool LER7646EZ1
Whirlpool LER7646EZ2
Whirlpool LER7646JQ0
Whirlpool LER7646JT0
Whirlpool LER7648KQ0
Whirlpool LER7648KQ1
Whirlpool LER7648KQ2
Whirlpool LER7648KQ3 29"electric Dryer
Whirlpool LER7648KT0
Whirlpool LER7648KT1
Whirlpool LER7648KT2
Whirlpool LER7648KT3 29"electric Dryer
Whirlpool LER7648PQ0 29" Electric Dryer
Whirlpool LER7648PQ1 29" Electric Dryer
Whirlpool LER7648PT0 29" Electric Dryer
Whirlpool LER7648PT1 29" Electric Dryer
Whirlpool LER7848DQ0
Whirlpool LER7848DQ1
Whirlpool LER7848DZ0
Whirlpool LER7848DZ1
Whirlpool LER7858AN0
Whirlpool LER7858AN1
Whirlpool LER7858AN2
Whirlpool LER7858AW0
Whirlpool LER7858AW1
Whirlpool LER7858AW2
Whirlpool LER8620PG0 29"electric Dryer
Whirlpool LER8620PG1 29"electric Dryer
Whirlpool LER8620PW0 29"electric Dryer
Whirlpool LER8620PW1 29"electric Dryer
Whirlpool LER8648LG0
Whirlpool LER8648LG1 29"electric Dryer
Whirlpool LER8648LQ0
Whirlpool LER8648LW0
Whirlpool LER8648LW1 29"electric Dryer
Whirlpool LER8648PG0 29"electric Dryer
Whirlpool LER8648PG1 29"electric Dryer
Whirlpool LER8648PQ0 29" Electric Dryer
Whirlpool LER8648PQ1 29"electric Dryer
Whirlpool LER8648PW0 29"electric Dryer
Whirlpool LER8648PW1 29"electric Dryer
Whirlpool LER8857EQ0
Whirlpool LER8857EQ1
Whirlpool LER8857EQ2
Whirlpool LER8857EZ0
Whirlpool LER8857EZ1
Whirlpool LER8857EZ2
Whirlpool LER8858DQ0
Whirlpool LER8858DQ1
Whirlpool LER8858DZ0
Whirlpool LER8858DZ1
Whirlpool LER8858EQ0
Whirlpool LER8858EQ1
Whirlpool LER8858EQ2
Whirlpool LER8858EZ0
Whirlpool LER8858EZ1
Whirlpool LER8858EZ2
Amana LES10AW Washer - Top Loading
Amana LES19AW Dryer - Gas
Amana LES33AW Dryer - Gas
Amana LES34AW Washer - Top Loading
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Amana LET-480 Range - S/c S/i Ddraft Gas
Amana LET-480A Range - S/c S/i Ddraft Gas
Amana LET-480B Range - S/c S/i Ddraft Gas
Amana LET-480C Range - S/c S/i Ddraft Gas
Whirlpool LET5434AN0
Whirlpool LET5434AQ0
Whirlpool LET5434AW0
Whirlpool LET5436AN0
Whirlpool LET5436AW0
Whirlpool LET5624BN0
Whirlpool LET5624BN1
Whirlpool LET5624BN2
Whirlpool LET5624BQ0
Whirlpool LET5624BQ1
Whirlpool LET5624BQ2
Whirlpool LET5624BW0
Whirlpool LET5624BW1
Whirlpool LET5624BW2
Whirlpool LET5624DQ0
Whirlpool LET5624DQ1
Whirlpool LET6634AN0
Whirlpool LET6634AN1
Whirlpool LET6634AN2
Whirlpool LET6634AQ0
Whirlpool LET6634AQ1
Whirlpool LET6634AQ2
Whirlpool LET6634AW0
Whirlpool LET6634AW1
Whirlpool LET6634AW2
Whirlpool LET6634DQ0
Whirlpool LET6634DQ1
Whirlpool LET6634DZ0
Whirlpool LET6634DZ1
Whirlpool LET6638AN0
Whirlpool LET6638AN1
Whirlpool LET6638AN2
Whirlpool LET6638AQ2
Whirlpool LET6638AW0
Whirlpool LET6638AW1
Whirlpool LET6638AW2
Whirlpool LET6638DQ0
Whirlpool LET6638DQ1
Whirlpool LET6638DZ0
Whirlpool LET6638DZ1
Whirlpool LET7646AN0
Whirlpool LET7646AQ0
Whirlpool LET7646AQ1
Whirlpool LET7646AQ2
Whirlpool LET7646AW0
Whirlpool LET7646AZ0
Whirlpool LET7646AZ1
Whirlpool LET7646AZ2
Whirlpool LET7646DQ0
Whirlpool LET7646DQ1
Whirlpool LET7646DZ0
  #2 (permalink)
Old 08-20-2011, 08:00 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL LER7646EQ2 ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
I would start by checking the power.
The heater runs off of the 240 volts (L1 to L2) so that is what you have to check for.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If the power is OK unplug the unit and check the thermostats, all should be 0 ohms at room temperature.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat dsumption Oven Repair (including Ranges and Cooktops) 3 04-04-2011 05:03 PM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 02:23 PM
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 09:33 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
