Discuss
Dryer stopped mid drying cycle and won't start again
 in
Dryer Repair
Hello, I'm new to this forum. Our Maytag dryer stopped running mid drying cycle today and won't start
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer stopped mid drying cycle and won't start again
  #1 (permalink)
Old 11-24-2007, 07:50 PM
scsimpson scsimpson is offline
Junior Member
scsimpson is on a distinguished road
Default Dryer stopped mid drying cycle and won't start again
Model Number: MDE9557AYW   Brand: Maytag   Age: More than 10 years
Hello, I'm new to this forum. Our Maytag dryer stopped running mid drying cycle today and won't start again. It just stopped running. I checked the main service panel. The dryer breakers weren't flipped. I reset them anyway. The light inside the drum comes on when the door is opened. The dryer has no other signs of life, other than the drum light, no matter which dial is turned or button pushed. No burned smells. No sounds. Nothing. I figure we've had this dryer somewhere between 10-15 years. Never had any problems with it before today. I think since it died mid cycle that it's probably the motor? Could it be the start switch since it died mid dry cycle?
Thank you in advance!
Scott
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-25-2007, 07:05 AM
jumptrout51 jumptrout51 is offline
Expert
APP Volunteer
jumptrout51 is on a distinguished road
Default
Check the door switch for continuity. Maytag also has a thermal switch(not resettable) that will blow. If thermal switch is bad check your vent for poor airflow.
  #3 (permalink)
Old 11-25-2007, 07:44 PM
Junior Member
Default
Got my hands on a Fluke multi tester today. Start switch, Temp switch, the two thermal switches I could find and the door switch (light comes on when door is opened) all tested good. The timer motor gave me a reading of 6.3K ohm though. My repair book says it should be between 2-3K. So, I suspect the timer motor. Is 6.3K ohm too high? I'm electrically challenged which is why I ask.
None of the air ducts were clogged but were sort of linty so I cleaned them all out from the drum to the outside vent in the wall as well as all around the inside the dryer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No or limited heat during drying cycle roles120 Dryer Repair 4 09-11-2008 04:06 PM
Dryer not drying sue1759 Dryer Repair 5 11-02-2007 06:09 PM
Top of Dryer hot but clothes not drying sween Dryer Repair 4 10-27-2007 01:29 PM
Gas Dryer not drying during run cycles GMP Dryer Repair 1 09-28-2007 08:42 AM
Dryer stopped and won't start Help4mom Dryer Repair 3 09-14-2007 03:58 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
