Discuss
Roper Gas Dryer won't shut off in auto dry
 in
Dryer Repair
My timer will advance in timed setting but not during auto sense dry, I have heat. I replaced the thermal
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Roper Gas Dryer won't shut off in auto dry
  #1 (permalink)
Old 03-30-2009, 06:50 PM
Junior Member
yucaipahunter is on a distinguished road
Default Roper Gas Dryer won't shut off in auto dry
Model Number: RGS7646KQ1   Brand: Roper   Age: 5 - 10 years
My timer will advance in timed setting but not during auto sense dry, I have heat. I replaced the thermal fuse not long ago. I replaced the cycling thermostat ( it was good) the hi temp has continuity, exhaust duct free and clear, dryer heat cycles on and off pretty frequently, temp at exhaust was about 140+- How can I test my timer to be sure ? I followed some tests in my wiring diagram with my meter and most "zeroed" out however on the Auto hi temp setting I measured some resistance, (between TM-WB) not normal right?I just want to make sure before I buy a new timer. Any help would be great.
Related Models
Roper RGS7646KQ1 RESIDENTIAL DRYER
Roper RGS7646KQ2 DRYER
Roper RGS7646KQ3 29" GAS DRYER
Roper RGS7648EN0 GAS DRYER
Roper RGS7648EN2 GAS DRYER
Roper RGS7648EN3 GAS DRYER
Roper RGS7648EQ0 GAS DRYER
Roper RGS7648EQ2 GAS DRYER
Roper RGS7648EQ3 GAS DRYER
Roper RGS7648EW0 GAS DRYER
Roper RGS7648EW2 GAS DRYER
Roper RGS7648EW3 GAS DRYER
Roper RGS7648JQ0 GAS DRYER
Roper RGS7648JQ1 RESIDENTIAL DRYER
Roper RGS7648KQ1 RESIDENTIAL DRYER
Roper RGS7648KQ2 DRYER
Roper RGS7745PQ0 29" GAS DRYER
Roper RGS7745RQ0 29" GAS DRYER
Roper RGS7745RQ1 29" GAS DRYER
 RGSF3330DW RANGE- S/C F/S GAS
 RGSF5330DT RANGE- S/C F/S GAS
Amana RGT350UD SURFACE UNIT- GAS
Amana RGT350UWW SURFACE UNIT- GAS
Amana RGT650UD SURFACE UNIT- GAS
Amana RGT650UWW SURFACE UNIT- GAS
General Electric RGU32N01 Gas range
General Electric RGU32U01 Gas range
General Electric RGU32U02 Gas range
General Electric RGU3501A Gas range
General Electric RGU6501A Gas range
Roper RGX3514PQ0 29" GAS DRYER
Roper RGX3514RQ0 29" GAS DRYER
Roper RGX3514RQ1 29" GAS DRYER
Roper RGX3519PQ0 29" GAS DRYER
Roper RGX3615EW0 GAS DRYER
Roper RGX4624EN0 GAS DRYER
Roper RGX4625EN0 GAS DRYER
Roper RGX4625EW0 GAS DRYER
Roper RGX4625EW1 DRYERS
Roper RGX4625EW2 GAS DRYER
Roper RGX4625EW3 GAS DRYER
Roper RGX4634JQ0 DRYER
Roper RGX4634KQ1 DRYER
Roper RGX4634KQ2 DRYER
Roper RGX4634KQ3 29" GAS DRYER
Roper RGX4635EN0 GAS DRYER
Roper RGX4635EN1 DRYERS
Roper RGX4635EN2 GAS DRYER
Roper RGX4635EN3 GAS DRYER
Roper RGX4635EQ0 GAS DRYER
Roper RGX4635EQ1 DRYERS
Roper RGX4635EQ2 GAS DRYER
Roper RGX4635EQ3 GAS DRYER
Roper RGX4635EW0 GAS DRYER
Roper RGX4635EW1 DRYERS
Roper RGX4635EW2 GAS DRYER
Roper RGX4635EW3 GAS DRYER
Roper RGX5634JQ0 DRYER
Roper RGX5634JQ1 DRYER
Roper RGX5634KQ1 DRYER
Roper RGX5634KQ2 DRYER
Roper RGX5634KQ3 29" GAS DRYER
Roper RGX5634PQ0 29" GAS DRYER
Roper RGX5635EN0 GAS DRYER
Roper RGX5635EN1 DRYERS
Roper RGX5635EN2 GAS DRYER
Roper RGX5635EN3 GAS DRYER
Roper RGX5635EQ0 GAS DRYER
Roper RGX5635EQ1 DRYERS
Roper RGX5635EQ2 GAS DRYER
Roper RGX5635EQ3 GAS DRYER
Roper RGX5635EW0 GAS DRYER
Roper RGX5635EW1 DRYERS
Roper RGX5635EW2 GAS DRYER
Roper RGX5635EW3 GAS DRYER
Roper RGX5636AL1 GAS DRYER
Roper RGX5636AL2 GAS DRYER
Roper RGX5636AW0 Residential Dryer
Roper RGX5636AW1 GAS DRYER
Roper RGX5636AW2 GAS DRYER
Roper RGX6634PQ0 29" GAS DRYER
Roper RGX6634RQ0 29" GAS DRYER
Roper RGX6634RQ1 29" GAS DRYER
Roper RGX6646AL1 GAS DRYER
Roper RGX6646AL2 GAS DRYER
Roper RGX6646AL3 GAS DRYER
Roper RGX6646AQ2 GAS DRYER
Roper RGX6646AQ3 GAS DRYER
Roper RGX6646AW0 Residential Dryer
Roper RGX6646AW1 GAS DRYER
Roper RGX6646AW2 GAS DRYER
Roper RGX6646AW3 GAS DRYER
Roper RH0500RAW00 CHEST FREEZER
Roper RH0500RDW00 CHEST FREEZER
Roper RH0500REW00 CHEST FREEZER
Roper RH0500REW01 CHEST FREEZER
Roper RH0500REW02 CHEST FREEZER
Roper RH0500RWW00 Freezers*
Roper RH0588RBW00 CHEST FREEZER
Roper RH0588REW00 CHEST FREEZER
Roper RH0588REW01 CHEST FREEZER
Roper RH0588REW02 CHEST FREEZER
Roper RH0599RBW00 CHEST FREEZER
Roper RH0599REW00 CHEST FREEZER
Roper RH0599REW01 CHEST FREEZER
Roper RH0599REW02 CHEST FREEZER
Roper RH0799RBW00 CHEST FREEZER
Roper RH0799REW00 CHEST FREEZER
Roper RH0799REW01 CHEST FREEZER
Roper RH0799REW06 FREEZERS
Jenn-Air RH100 HOOD
Roper RH1000RAW00 Freezers*
Roper RH1000RDW00 CHEST FREEZER
Roper RH1000REW00 CHEST FREEZER
Roper RH1000REW01 CHEST FREEZER
Roper RH1000REW05 CHEST FREEZER
Roper RH1000REW06 FREEZERS
Roper RH1000RYW00 Freezers*
Jenn-Air RH101 HOOD
Roper RH1099RBW00 CHEST FREEZER
  #2 (permalink)
Old 03-30-2009, 07:16 PM
Junior Member
Default
I mentioned earlier the heat cycles frequently, what is the average run time for a heat cycle ? My flame seems to only blow for about 20-30 seconds then start up in a bit and do the same ,on /off on /off is this normal ? Thanks
  #3 (permalink)
Old 03-31-2009, 03:44 PM
Junior Member
Default
OK no help yet but, to update I replaced the gas valve coils thinking I wasn't getting enough heat, made no difference. I also used an infrared thermometer at the exhaust and my temp is about 125-130 it varies. The heater still cycles pretty frequently and the timer still will not advance in auto setting. I have replaced: thermal fuse, cycling thermostat, gas valve coils, tested the hi limit and by passed it thinking it might be weak, no difference. Any suggestions ? Is it the timer ? What else can I check ? Thanks
  #4 (permalink)
Old 04-02-2009, 08:11 PM
Junior Member
Default
Opinions, Advice, Help, anyone, Gene ? Thanks. Anyone else have this problem ?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
auto shut-down after 3-5 seconds lovenaz1940 Dishwasher Repair 4 05-07-2010 06:49 AM
Dryer heats in auto but wont shut off CSH12H Dryer Repair 1 10-16-2009 11:51 AM
Auto Sensing Electric Dryer mrhyde25 Dryer Repair 1 09-24-2009 02:33 PM
No Dryer Heat/No shut of in auto cycle fred2117 Dryer Repair 4 04-30-2009 04:59 PM
dryer timer/auto will not work FJM122 Dryer Repair 1 12-09-2008 10:23 AM
