| » Nothing works |
Model Number: ADE70005AYW Brand: Admiral Age: 5 - 10 years
My wife smelled something burning while drying a load of laundry so for what ever reason she unplugged the dryer from the 240VAC wall outlet. When she plugged it back up it would not work at all including no light. I can here the timer clicking once set. I checked the input power at the terminal strip (good) checked the thermal fuse dead short (good) checked for a overload protector on the motor not found. I also checked the on off switch which was .o1OHMS on or off with both wires disconnected. I shorted the wires and nothing. Tested door switch (good). Is there a glass or ceramic fuse on the unit?
any ideas please help. Oh yea I moved the unit drum around and one out of two of the heating elements lit up extremly hot and went off. I could not recreate the problem. Ads By Google Related Models Last edited by Brad Turner : 03-30-2009 at 06:36 AM. |
Could not find a ADE70005AYW, so assumed this was just a typo following are for a ADE7005AYW
Here are your parts Replacement parts for ADMIRAL ADE7005AYW | AppliancePartsPros.com Here is a wiring diagram http://www.servicematters.com/maytag...s/16027525.pdf Here is a service manual http://www.servicematters.com/maytag...s/16026315.pdf it would not work at all including no light. I can here the timer clicking once set. I checked the input power at the terminal strip (good) Did you check both sides of the line for 120 volts? The light uses one side of the line (120 volts) also the motor. Perhaps you have lost Neutral. checked for a overload protector on the motor not found The overload is inside the motor I also checked the on off switch which was .o1OHMS on or off with both wires disconnected. By on off switch I assume you mean the Push To Start, with the wires disconnected this does indicate a problem. It should open and close Is there a glass or ceramic fuse on the unit? No. Unit only has the one Item 6 in "Base, heater" section Oh yea I moved the unit drum around and one out of two of the heating elements lit up extremly hot and went off. From what I see the unit only has one heater. Looks like you have the 240 volts as you had high heat. By turning the drum, you turned the motor which closed the centrifugal switches and you had heat. Since the door was open air was not pulled over the heating element hence the extreme heat. You may have blown the thermal fuse or the heater itself.
__________________
| Display Modes | |
| HELP: wash cycles won't drain/spin, manual rinse/drain works, manual drain/spin works | cosmo99 | Washer Repair | 1 | 01-27-2010 11:33 AM |
| Wall oven bake element not working! Broil works, clock works. | ajachyra | Oven Repair (including Ranges and Cooktops) | 1 | 12-02-2009 06:30 AM |
| Oven will not turn on, broiler works, stove top works | caewart | Oven Repair (including Ranges and Cooktops) | 1 | 06-20-2009 05:25 AM |
| Dryer Works, Doesnt Work, Works Again | timber284 | Dryer Repair | 0 | 08-01-2008 09:56 AM |
| GE oven stove top works, ignitor works, no gas flow in oven | mikeburton@cableone.net | Oven Repair (including Ranges and Cooktops) | 1 | 12-26-2007 07:09 PM |
