I purchased a new heating element,and a thermal cutoff kit.. but the parts in the kit are not a match,the new part is not a direct connect,and uses a jumper wire,but if I do it according to the instructions,it leaves 2 wires from the harness that have no place to connect.. does anyone know if this is how it should be using the new kit,and where would the 2 wires left in the harness connect to..?
