Discuss
Dryer keeps running and no doesn't heat
 in
Dryer Repair
I placed my clothes in the dryer and went back to get them they were not dry and the dryer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer keeps running and no doesn't heat
  #1 (permalink)
Old 11-23-2007, 10:59 PM
Junior Member
sheila30083 is on a distinguished road
Unhappy Dryer keeps running and no doesn't heat
Brand: GE   Age: 5 - 10 years
I placed my clothes in the dryer and went back to get them they were not dry and the dryer was still running with no heat.
Ads By Google
  #2 (permalink)
Old 11-24-2007, 06:51 PM
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
the first thing to check is the fuses or breakers to make sure there,s 240 volts going to the dryer..
__________________
  #3 (permalink)
Old 11-25-2007, 05:53 AM
Junior Member
Default Dryer keeps running and there no heat I have to shut it off
The dy doesn't stop and there no heat
  #4 (permalink)
Old 11-25-2007, 07:50 AM
Senior Expert
APP Volunteer
Default
sounds like a fuse or breaker there are two fuses or breakers .One will run the motor the other one the heat , if this dryer is not an appartment size dryer[small unit] then check both fuses/breakers..
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Gas dryer running but no heat RBYRD9.1 Dryer Repair 80 08-17-2011 10:18 PM
Dryer running but won't heat pm3009 Dryer Repair 2 09-05-2008 04:19 PM
Dryer running with no heat rotty Dryer Repair 1 11-21-2007 08:45 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
