Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Dryer keeps running and no doesn't heat (http://forum.appliancepartspros.com/dryer-repair/2790-dryer-keeps-running-no-doesnt-heat.html)
sheila30083 11-23-2007 10:59 PM
I placed my clothes in the dryer and went back to get them they were not dry and the dryer was still running with no heat.
abbie 11-24-2007 06:51 PM
the first thing to check is the fuses or breakers to make sure there,s 240 volts going to the dryer..
sheila30083 11-25-2007 05:53 AM
Dryer keeps running and there no heat I have to shut it off
;) The dy doesn't stop and there no heat
abbie 11-25-2007 07:50 AM
sounds like a fuse or breaker there are two fuses or breakers .One will run the motor the other one the heat , if this dryer is not an appartment size dryer[small unit] then check both fuses/breakers..
