Discuss
Maytag Neptune gas dyer does not stay hot
 in
Dryer Repair
I have a Maytag Neptune gas dryer model MDG5500. When turned ON after not being used for at least 15
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Neptune gas dyer does not stay hot
  #1 (permalink)
Old 03-28-2009, 10:52 AM
Junior Member
squarecookie is on a distinguished road
Default Maytag Neptune gas dyer does not stay hot
Model Number: MDG5500   Brand: Maytag   Age: 5 - 10 years
I have a Maytag Neptune gas dryer model MDG5500. When turned ON after not being used for at least 15 minutes, the dryer tumbles and begins to heat up in either the sensor dry mode or the wrinkle release mode. When in the sensor mode, sometimes it seems to dry the load normally. But most of the time, after initially heating up, I return to find the dryer tumbling the clothes but it is cold inside and the clothes are very damp. If I restart the cycle or switch to wrinkle release, I still get no heat. If I turn the dryer OFF for at least 15 minutes or longer and then restart, I get heat for a short time, but then no heat thereafter. I have good air flow to the outside vent, have vacuumed thoroughly the lint trap, vent, and behind the dryer.
Ads By Google
Related Models
Maytag MDG5500AWQ Dryer - Gas
Maytag MDG5500AWW Dryer - Gas
Maytag MDG5806AWK Dryer - Gas
Maytag MDG5806AWW Dryer - Gas
Maytag MDG5960BWW Dryer - Gas
Maytag MDG6000AWQ Dryer - Gas
Maytag MDG6000AWW Dryer - Gas
Maytag MDG6000AXW Dryer - Gas
Maytag MDG6000BWQ Dryer - Gas
Maytag MDG6000BWW Dryer - Gas
Maytag MDG6200AWQ Dryer - Gas
Maytag MDG6200AWW Dryer - Gas
Maytag MDG6400AWQ Dryer - Gas
Maytag MDG6400AWW Dryer - Gas
Maytag MDG6460AWW Dryer - Gas
Maytag MDG6657BWQ Dryer - Gas
Maytag MDG6657BWW Dryer - Gas
Maytag MDG6700AWM Dryer - Gas
Maytag MDG6700AWW Dryer - Gas
Maytag MDG6800AWB Dryer - Gas
Maytag MDG6800AWQ Dryer - Gas
Maytag MDG6800AWW Dryer - Gas
Maytag MDG7057AWQ Dryer - Gas
Maytag MDG7057AWW Dryer - Gas
Maytag MDG7057BWQ Dryer - Gas
Maytag MDG7057BWW Dryer - Gas
Maytag MDG7400AWQ Dryer - Gas
Maytag MDG7400AWW Dryer - Gas
Maytag MDG7460AWQ Dryer - Gas
Maytag MDG7460AWW Dryer - Gas
Maytag MDG7500AWQ Dryer - Gas
Maytag MDG7500AWW Dryer - Gas
Maytag MDG75MNAWW Dryer - Gas
Maytag MDG75MNVWQ Dryer - Gas
Maytag MDG75MNVWW Dryer - Gas
Maytag MDG75PN1AW Dryer - Gas
Maytag MDG75PN2VW Dryer - Gas
Maytag MDG75PNAVW Dryer - Gas
Maytag MDG75PNHWQ Dryer - Gas
Maytag MDG75PNHWW Dryer - Gas
Maytag MDG75PNVVQ Dryer - Gas
Maytag MDG75PNVVW Dryer - Gas
Maytag MDG75PNVWQ Dryer - Gas
Maytag MDG75PNVWW Dryer - Gas
Maytag MDG7600AWQ Dryer - Gas
Maytag MDG7600AWW Dryer - Gas
Maytag MDG7657AWQ Dryer - Gas
Maytag MDG7657AWW Dryer - Gas
Maytag MDG7657BWQ Dryer - Gas
Maytag MDG7657BWW Dryer - Gas
Maytag MDG7658AWQ Dryer - Gas
Maytag MDG7658AWW Dryer - Gas
Maytag MDG7658BWQ Dryer - Gas
Maytag MDG7658BWW Dryer - Gas
Maytag MDG76PCBWS Dryer - Gas
Maytag MDG76PCBWW Dryer - Gas
Maytag MDG7757AWQ Dryer - Gas
Maytag MDG7757AWW Dryer - Gas
Maytag MDG7758AWQ Dryer - Gas
Maytag MDG7758AWW Dryer - Gas
Maytag MDG77PNAWW Dryer - Gas
Maytag MDG77PNSWW Dryer - Gas
Maytag MDG8000AWQ Dryer - Gas
Maytag MDG8000AWW Dryer - Gas
Maytag MDG8000BWQ Dryer - Gas
Maytag MDG8000BWW Dryer - Gas
Maytag MDG8057AWQ Dryer - Gas
Maytag MDG8057AWW Dryer - Gas
Maytag MDG8057BWQ Dryer - Gas
Maytag MDG8057BWW Dryer - Gas
Maytag MDG8058BWQ Dryer - Gas
Maytag MDG8058BWW Dryer - Gas
Maytag MDG8400AWQ Dryer - Gas
Maytag MDG8400AWW Dryer - Gas
Maytag MDG8416AWA Dryer - Gas
Maytag MDG8416AWW Dryer - Gas
International MDG8426AAW Dryer - Gas
International MDG8426AEW Dryer - Gas
International MDG8426AGW Dryer - Gas
Maytag MDG8500BWW Dryer - Gas
Maytag MDG8506AWA Dryer - Gas
Maytag MDG8506AWW Dryer - Gas
International MDG8550AGW Dryer - Gas
International MDG8550BGW Dryer - Gas
Maytag MDG8600AWQ Dryer - Gas
Maytag MDG8600AWW Dryer - Gas
Maytag MDG8757AWQ Dryer - Gas
Maytag MDG8757AWW Dryer - Gas
Maytag MDG9206AWA Dryer - Gas
Maytag MDG9206AWW Dryer - Gas
Maytag MDG9206AXW Dryer - Gas
Maytag MDG9206BWW Dryer - Gas
Maytag MDG9306AWA Dryer - Gas
Maytag MDG9306AWW Dryer - Gas
Maytag MDG9306AXA Dryer - Gas
Maytag MDG9306AXW Dryer - Gas
Maytag MDG9316AWA Dryer - Gas
Maytag MDG9316AWQ Dryer - Gas
Maytag MDG9316AWW Dryer - Gas
Maytag MDG9316AXW Dryer - Gas
Maytag MDG9316BWQ Dryer - Gas
Maytag MDG9316BWW Dryer - Gas
Maytag MDG9357AWA Dryer - Gas
Maytag MDG9357AWQ Dryer - Ele
Maytag MDG9357AWW Dryer - Gas
Maytag MDG9360BWW Dryer - Gas
Maytag MDG9390AWW Dryer - Gas
Maytag MDG9390AXW Dryer - Gas
Maytag MDG9390BWW Dryer - Gas
Maytag MDG9420BWW Dryer - Gas
Maytag MDG9520BWQ Dryer - Gas
Maytag MDG9520BWW Dryer - Gas
Maytag MDG9557AWA Dryer - Gas
Maytag MDG9557AWQ Dryer - Gas
Maytag MDG9557AWW Dryer - Gas
Maytag MDG9557AXQ Dryer - Gas
Maytag MDG9557AXW Dryer - Gas
Maytag MDG9557BWQ Dryer - Gas
Maytag MDG9557BWW Dryer - Gas
Maytag MDG9606AWA Dryer - Gas
  #2 (permalink)
Old 03-28-2009, 12:46 PM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
it is most likely the coils on the gas valve getting weak. replace them both, and that should do it. it is a cheap, and easy repair. tom
  #3 (permalink)
Old 03-29-2009, 12:27 PM
Junior Member
laloct is on a distinguished road
Default
Quote:
i have maytag gas drier mdg4658aww. when power is switched on, the motor does not move. it seems the power is there in control board but beyond that there is no movement. gas exhaust duct has been cleaned. is it because of fuse is tripped or any other problem? is entire control board has to be replaced?
  #4 (permalink)
Old 04-19-2009, 08:50 AM
Junior Member
Default
Update: New coils installed and the dryer is staying hot through the entire cycle. Finally, dry clothes. Goodbye, clothesline. Thank you!! Hardest part of the job was figuring out how to get inside the dryer to access the coils (removed door, then pulled back front panel).
  #5 (permalink)
Old 04-20-2009, 04:39 AM
Senior Expert
APP Volunteer
Default
Good Job, that is the way to save the cash. Tom ********************************************
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dyer won't stay running GoldaLn Dryer Repair 1 01-15-2010 03:05 AM
Neptune won't stay spinning sadist smythe Washer Repair 4 01-02-2010 06:28 AM
Maytag dyer motor problems TRULUCK Dryer Repair 7 12-16-2009 05:06 PM
maytag dyer fcharcoal Heating, Ventilation, and Air Conditioning (HVAC) 2 11-24-2009 10:04 AM
Maytag performa dyer humberguy Dryer Repair 3 10-16-2008 04:18 AM
