Discuss
Drum wont stop spinning
 in
Dryer Repair
Hello, I have a LG DLE3733W Dryer which is about 2 years old. A few weeks ago the dryer started
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Drum wont stop spinning
  #1 (permalink)
Old 08-06-2011, 01:22 PM
Junior Member
RickSim is on a distinguished road
Default Drum wont stop spinning
Model Number: DLE3733W   Brand: -other-   Age: 1 - 5 years
Hello,
I have a LG DLE3733W Dryer which is about 2 years old. A few weeks ago the dryer started doing something bizarre... the drum wont stop turning even after the program has completed. The only way to stop it is to unplug the dryer itself (its electric not gas), the moment you plug it in again the drum begins spinning even before you press the power button on the front of the unit.
I studied the service manual intensely, and came to the conclusion that it must be the centrifuge switch on the motor. I purchased a replacement motor, and installed it today. When I plugged the dryer in, it started spinning right away again. At this point im not sure what to do....
I put the dryer into diagnostic mode, and get the following codes right off the bat (no pressing the start button at all)...
1U:01
18:E8
The CHK FILTER light is also on perpetually once you turn the unit on.
Can anyone tell me with certainty what is wrong here so I can figure out the correct part to purchase, and fix this thing once and for all?
Thanks,
Rick
Related Models
 DLE3733W Dryer
 DLE3777W Dryer
 DLE5932S Dryer
 DLE5932W Dryer
 DLE5955G Dryer
 DLE5955W Dryer
 DLE5977B Dryer
 DLE5977S Dryer
 DLE5977SM Dryer
 DLE5977W Dryer
 DLE6942W Dryer
 DLE7177RM Dryer
 DLE7177WM Dryer
 DLE8377NM Dryer
 DLE8377WM Dryer
 DLE9577SM Dryer
 DLE9577WM Dryer
 DLEC733W Dryer
 DLEV833W Dryer
 DLEX0001TM Dryer
 DLEX2801L Dryer
 DLEX2801W Dryer
 DLEX3001P Dryer
 DLEX3001R Dryer
 DLEX3001W Dryer
 DLG0332W Dryer
 DLG0452G Dryer
 DLG0452W Dryer
 DLG1320W Dryer
Amana DLG231RAW DRYER- GAS
 DLG2522W Dryer
 DLG2524W Dryer
 DLG2525S Dryer
 DLG2526W Dryer
 DLG2532W Dryer
 DLG2602W Dryer
Amana DLG330RAW DRYER- GAS
Amana DLG330RCW DRYER- GAS
 DLG3744D Dryer
 DLG3744S Dryer
 DLG3744U Dryer
 DLG3744W Dryer
 DLG3788W Dryer
 DLG5932S Dryer
 DLG5932W Dryer
 DLG5966G Dryer
 DLG5966W Dryer
 DLG5988B Dryer
 DLG5988S Dryer
 DLG5988SM Dryer
 DLG5988W Dryer
 DLG6952W Dryer
 DLG7188RM Dryer
 DLG7188WM Dryer
 DLG8388NM Dryer
 DLG8388WM Dryer
 DLG9588SM Dryer
 DLG9588WM Dryer
 DLGX0002TM Dryer
 DLGX2802W Dryer
 DLGX3002P Dryer
 DLGX3002R Dryer
 DLGX3002W Dryer
General Electric DLL1550ABL Electric dryer
General Electric DLL1550BAL Gas dryer
General Electric DLL1550BBL Gas dryer
General Electric DLL1550BCL Gas dryer
General Electric DLL1550BDL Gas dryer
General Electric DLL1550BEL Gas dryer
General Electric DLL1550BFL Gas dryer
General Electric DLL1550BGL Gas dryer
General Electric DLL1550BHL Gas dryer
General Electric DLL1550RAL Gas dryer
General Electric DLL1550RBL Gas dryer
General Electric DLL1550RCL Gas dryer
General Electric DLL1550SBLAD Gas dryer
General Electric DLL1550SBLWH Gas dryer
General Electric DLL2450BGL Gas dryer
General Electric DLL2450BHL Gas dryer
General Electric DLL2450RAL Gas dryer
General Electric DLL2450RBL Gas dryer
General Electric DLL2450RCL Gas dryer
General Electric DLL2650ABL Electric dryer
General Electric DLL2650BAL Gas dryer
General Electric DLL2650BBL Gas dryer
General Electric DLL2650BCL Gas dryer
General Electric DLL2650BDL Gas dryer
General Electric DLL2650BEL Gas dryer
General Electric DLL2650BFL Gas dryer
General Electric DLL2650BGL Gas dryer
General Electric DLL2650BHL Gas dryer
General Electric DLL2650BJL Gas dryer
General Electric DLL2650RAL BACKSPLASH DRYER WOW
General Electric DLL2650RALWW Gas dryer
General Electric DLL2650RBL BACKSPLASH DRYER PROGRAM
General Electric DLL2650RBLWW Gas dryer
General Electric DLL2650RCL GAS DRYER
General Electric DLL2650RCLWW Gas dryer
General Electric DLL2650TA Electric dryer
General Electric DLL2654TA Electric dryer
General Electric DLL2750BAL Gas dryer
General Electric DLL2750BBL Gas dryer
General Electric DLL2880ABC Electric dryer
General Electric DLL2880BAC Electric dryer
General Electric DLL2880DAL Gas dryer
General Electric DLL2880DBL Gas dryer
General Electric DLL2880DCL Gas dryer
General Electric DLL2880DGL Gas dryer
General Electric DLL2880DHL Gas dryer
General Electric DLL2880DJL Gas dryer
General Electric DLL2880DKL Gas dryer
General Electric DLL2880DLL Gas dryer
General Electric DLL2880DML Gas dryer
General Electric DLL2880TA Electric dryer
General Electric DLL2884TA Electric dryer
General Electric DLL2884TB Electric dryer
General Electric DLL2900MAL Gas dryer
  #2 (permalink)
Old 08-06-2011, 03:02 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Did you find the service manual on the net and if yes where?
Have you tried opening the door to see if that stops it?
Sounds like a control board problem but I would like to confirm this guess but I cannot find the manual/wiring diagram.
The centrifugal switch would not cause the motor to start on it's own as usually all it is doing is switching out the start winding. If anything it would stop the motor from starting and it would sit there and buzz.
__________________
  #3 (permalink)
Old 08-06-2011, 05:56 PM
Junior Member
Default The service manual
Hello,
http://www.appliancefactoryparts.com...dfs/125401.pdf
The service manual can be found here. I suspected the centrifugal switch because I read on some other forums about the motor being stuck "open" or "closed". The behavior to me said "stuck open" so I replaced the motor thinking this was the most obvious issue. At least Im now prepared with a second motor for whenever the motor does give. Also had some good practice taking the dryer apart, and putting it back together.
Very simple to do, trickiest part was putting the belt back on the drum, motor and tensioner pulley.
And yes, the drum does stop when you open the door (even when the dryer is "off"), but resumed immediately upon the door being closed again.
Thanks,
Rick
  #4 (permalink)
Old 08-07-2011, 10:37 AM
Senior Expert
APP Volunteer
Default
It does sound like the control board.
I would check the thermistor resistance just to be sure that they are not doing some strange monitoring of it.
__________________
  #5 (permalink)
Old 10-01-2012, 07:31 AM
Junior Member
sonny67 is on a distinguished road
Default
My Maytag is doing the same thing. It started doing it last night after I tried to dry a load. When I hit the start button I herd what sounded like a lot of change falling through the machine and than it just lost all power. It blew a breaker. I reset the breaker and now the dryer spins all the time, no heat it just spins. I tried to go throught the setting and starting a cycle and everything seems to work as it should except the fact the thing wont stop spinning untill I unplug it or open the door.
Did you ever end up figuring out what was wrong with your? If so what was the problem and how did you fix it? Any help would be greatly appreciated.
Thanks,
Paul
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washing machine wont stop spinning . is this the timer jcobbler4 Washer Repair 0 02-05-2010 04:26 PM
lsr7233bw1 maytag drum is not spinning jjmartin1024 Washer Repair 1 12-20-2009 05:38 PM
Asko drum not spinning wkosbob Washer Repair 0 03-10-2009 04:58 PM
drum not spinning wilsw013 Washer Repair 0 02-25-2009 08:02 AM
Dryer Drum Not Spinning sportsmom1214 Dryer Repair 0 11-18-2007 10:07 AM
