| » Dryer will Not Run? |
Model Number: EED4300TQO Brand: Estate Age: 1 - 5 years
Replacement parts for WHIRLPOOL EED4300TQ0 | AppliancePartsPros.com Here is a wiring diagram https://www.servicematters.com/docs/...%208576793.pdf A possibility would be the start switch. Check it with a meter. Wiring diagram shows a fuse in the motor circuit but I cannot find it in the parts breakdown. It is usually attached to the blower and is often white. Note the unit also has a thermal fuse in the heater circuit but this is attached at the heater. If it is there check it with a meter. If it is blown be sure to clean and check your vent system and the blower. These are common causes for blowing the fuse. If you do not have a meter. Unplug the unit. Short the two wires together. Tape them up so they cannot short to the frame. Plug it in and give it a try. If it runs get a replacement fuse ASAP as this is a major safety device. Prevents dryer and vent fires.
__________________
| Display Modes | |
