Discuss
Admiral dryer
 in
Dryer Repair
My dryer quit working. Being the smart person that I am I figured. No problem it has to be the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Admiral dryer
  #1 (permalink)
Old 08-02-2011, 11:28 AM
Junior Member
jacklandgraf is on a distinguished road
Default Admiral dryer
Model Number: LNC7764A71   Brand: Admiral   Age: 5 - 10 years
My dryer quit working. Being the smart person that I am I figured. No problem it has to be the timer mechanism. I replaced the time after ordering a new one, wire by wire I switched out ( obviouslly screwed up )I checked continuity and it actully turned out to be one of the high heat element. I got a new parts kit that had a switch that I rereplaced and two other thermo's (one for a gas dryer and one for an electric dryer. I checked the continuity of the faulty therm. and it had blown. Now I have a dryer that has a new timer but is obviously not hooked up properly. I have a wiring diagram but it means nothing to me. I need to be walked through the connections or see a color diagram with the wires hooked up properly. The whole problem stemed from the fact that the dryer was never vented properly and the accumalation of lint had almost completely closed of the dryer vent outlet
Thank you for any help you can give me. Jack
Ads By Google
Related Models
Admiral LNC7764A71 Dryer - Ele
Admiral LNC7764A77 Dryer - Ele
Admiral LNC7766A00 Dryer - Ele
International LNC7766A00 Dryer - Ele
Admiral LNC7766A71 Dryer - Ele
International LNC7766A71 Dryer - Ele
Admiral LNC7766B71 Dryer - Ele
International LNC8760A00 Dryer - Gas
International LNC8760A01 Dryer - Gas
International LNC8760A71 Dryer - Gas
International LNC8760A77 Dryer - Gas
Admiral LNC8764A00 Dryer - Gas
Admiral LNC8764A71 Dryer - Gas
Admiral LNC8766A00 Dryer - Gas
International LNC8766A00 Dryer - Gas
Admiral LNC8766A71 Dryer - Gas
International LNC8766A71 Dryer - Gas
Admiral LNC8766B71 Dryer - Gas
Amana LP13300.A Mwave - Family Size (60 Hz)
Amana LP13300.B Mwave - Family Size (60 Hz)
Amana LP13600.A Mwave - Family Size (60 Hz)
Amana LP13600.B Mwave - Family Size (60 Hz)
Amana LP13610.A Mwave - Family Size (60 Hz)
Amana LP13610.B Mwave - Family Size (60 Hz)
Amana LP16400.A Mwave - Family Size (60 Hz)
Amana LP16400.B Mwave - Family Size (60 Hz)
Amana LP16600.A Mwave - Family Size (60 Hz)
Amana LP16600.B Mwave - Family Size (60 Hz)
Amana LP16610.A Mwave - Family Size (60 Hz)
Amana LP16610.B Mwave - Family Size (60 Hz)
Amana LP24400.A Mwave - Family Size (60 Hz)
Amana LP24400.B Mwave - Family Size (60 Hz)
Amana LP24600.A Mwave - Family Size (60 Hz)
Amana LP24600.B Mwave - Family Size (60 Hz)
Amana LP83400.A Mwave - Family Size (60 Hz)
Amana LP83400.B Mwave - Family Size (60 Hz)
Amana LP83430.A Mwave - Family Size (60 Hz)
Amana LP83430.B Mwave - Family Size (60 Hz)
Amana LP83600.A Mwave - Family Size (60 Hz)
Amana LP83600.B Mwave - Family Size (60 Hz)
Amana LP83620.A Mwave - Family Size (60 Hz)
Amana LP83630.A Mwave - Family Size (60 Hz)
Amana LP83630.B Mwave - Family Size (60 Hz)
Admiral LPK5404ARW Kitchen Compact
Admiral LPK5404ARZ Kitchen Compact
Admiral LPR1115ADW Range - F/s Std Gas
Whirlpool LPR4231AG0
Whirlpool LPR4231AN0
Whirlpool LPR4231AW0
Whirlpool LPR6244AN0
Whirlpool LPR6244AW0
Maytag LRSC20A Ref - Sxs
Maytag LRSD20A Ref - Sxs
Maytag LRSD22A Ref - Sxs
Maytag LRSD24A Ref - Sxs
Maytag LRSW22A Ref - SXS/I&W
Maytag LRSW24A Ref - SXS/I&W
Maytag LRTC15A Ref - Top Mount
Maytag LRTC17A Ref - Top Mount
Maytag LRTC19A Ref - Top Mount
  #2 (permalink)
Old 08-03-2011, 02:37 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts includes a wiring diagram
Replacement parts for ADMIRAL LNC7764A71 DRYER- ELE | AppliancePartsPros.com
Note: the wiring diagram has a problem in that the right side of it is missing. L2 side of the line connects to the right side of MOTOR CENT. SWITCH.
You did not say what the current problem is so I am assuming that the unit still will not start.
First unplug the unit and one wire at the thermal fuse that you replaced and check it,
Would not be the first time a part was defective from a manufacturer.
If OK reattach the wire.
Next check the power (L1 to Neutral) (black to white) should be 120 volts.
Be very careful as 240 volts is lethal!!!
Try flipping the breaker slowly off/on a couple times. Sometimes you can loose half the line without tripping the breaker.
The only available info is the wiring diagram but you should be able to figure out any missing color codes by tracing the wires.
Unplug the dryer and set the timer to air fluff mid cycle.
Set your meter to the most sensitive ohms scale (usually 200 ohms on a digital meter).
Attach one meter lead to Neutral or ground if a 3 wire hook up and leave it there.
Now work you way back through the circuit.
F1 side of fuse should be 0 ohms.
F2 side of fuse should be 0ohms.
C on door switch should be 0 ohms.
N.O. (normally open) on door switch should be 0 ohms. Door must be closed.
WHITE (1) at the motor should be 0 ohms.
PURPLE (2) at the motor should be 2 to 4 ohms. This is the RUN and AUX motor windings.
PURPLE (S) at the timer should be 2 to 4 ohms.
ORANGE (M) at the timer should be 2 to 4 ohms.
BLACK (L) at the timer should be 2 to 4 ohms.
L1 at the line cord plug should be 2 to 4 ohms.
There you have now checked the motor's power circuit.
Here are some basic meter usage tips.
2. Always disconnect at least one side of any part you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
This depends if you are just measuring a part or checking a circuit path.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
Reply
« dryer | tub »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Admiral Gas Dryer seoulgrl Dryer Repair 3 11-04-2010 06:07 PM
Admiral Dryer JKWhitten Dryer Repair 0 06-30-2010 02:24 PM
Admiral dryer won't run mikey18610 Dryer Repair 2 10-10-2009 11:10 AM
Admiral dryer paco566 Dryer Repair 0 10-08-2009 02:59 PM
admiral dryer kojo Dryer Repair 2 03-13-2008 12:26 PM
