Motor was replacement for original. Appliance pro sent WE 17X10010 Motor kit which contained WE00X476 Motor. Centrifugal switch terminals are different from original with different sequence. Help.... I need to have someone describe the correct wiring connections on the new motor using the old motor wiring colors. I think Purple was on 1, Black on 2, yellow was on 4 blue on 5 and brown on 6. This does not seem to be correct for new terminals but I need to know if new numbers in fact correspond to old before I fry anything.I did not receive any installation wiring intructions for the dryer, with new motor package. Help......
