| » dryer timer and heat failure |
Model Number: 110.62212101 Brand: Kenmore Age: 5 - 10 years
Thanks for any help in advance. Kenmore dryer all of a sudden timed dry timer does not work and can get no heat from the dryer. Opened up from the back, dryer had limited lint on electrical components and wires. Seemed odd to me that the timer and heat would fail at the same time, and assuming malfunctioning component is related to both. This is an electric dryer.
The dryer runs, but will not shut off when in timed dry and no heat. Any help greatly appreciated. brian Ads By Google Related Models Last edited by brian52475 : 03-25-2009 at 05:52 AM. |
Here is a wiring diagram
https://www.servicematters.com/docs/...%208528187.pdf On this unit both the timer and heater run off of 240 volts. Try turning the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. If the above does not work measure the voltage at the plug, to be sure you have 240 volts.
__________________
| Display Modes | |
| dryer doesn't heat, timer hums | leedad06 | Dryer Repair | 0 | 12-03-2009 09:07 AM |
| Dryer timer AND heat | ogmike1973 | Dryer Repair | 1 | 10-18-2009 04:07 AM |
| Kenmore Dryer Timer not advancing in Auto Dry or Timer Mode but it does heat and dry | dspeidel | Dryer Repair | 6 | 08-25-2009 02:23 PM |
| dryer has no heat/timer dying | tomlizc | Dryer Repair | 3 | 05-10-2009 03:59 AM |
| Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. | NEAL AMES | Dryer Repair | 1 | 01-02-2009 06:40 PM |
