| » Timer Not Advancing |
Model Number: MDE9306AYW Brand: Maytag Age: 5 - 10 years
Origial problem was timer would not advance and automatically shut dryer off. Replaced timer, but problem still exist. Dryer is an auto sensing unit and should advance the timer as clothes get dryer. Dryer heats properly on all tempature settings. Timer advances properly and shuts dryer off when running in timed air fluff mode.
Is solution to replace the Thermostat with part # AP4038076? Is this thermostat sensor actually a "moisture sensor"? If this is not the correct solution, can you provide the correct solution(s)? Ads By Google Related Models |
Replacement parts for MAYTAG MDE9306AYW | AppliancePartsPros.com Here is a service manual http://www.servicematters.com/maytag...s/16023086.pdf See page 9-4 Is solution to replace the Thermostat with part # AP4038076? Is this thermostat sensor actually a "moisture sensor"? Not really a moisture sensor but it's normally open contacts provide power to the timer when the heater is shut off. If this is not the correct solution, can you provide the correct solution(s)? Looks like a good bet to me. Make sure to mark the wires before replacing it as it has normally open and normally closed contacts and an internal heater. Only way to check it is to heat the face up with a soldering gun till it trips and then measure the normally open contacts.
__________________
| Display Modes | |
| Timer not advancing | Dan71 | Dryer Repair | 3 | 10-13-2009 07:01 PM |
| Timer not advancing, no heat (sometimes) | mfornero | Dryer Repair | 0 | 10-11-2009 01:44 PM |
| Kenmore Dryer Timer not advancing in Auto Dry or Timer Mode but it does heat and dry | dspeidel | Dryer Repair | 6 | 08-25-2009 02:23 PM |
| Timer not advancing | suekea | Dryer Repair | 3 | 07-27-2008 08:17 AM |
| Timer not advancing | lparicio | Dryer Repair | 1 | 02-24-2008 11:51 AM |
