dryer works but blows out cool air, would it be right to order a dryer ignitor kit and bracket and a flame sensor? I really need it.
Originally Posted by: ANDREA ANDERSON dryer works but blows out cool air, would it be right to order a dryer ignitor kit and bracket and a flame sensor? I really need it. Andrea, That'd be a good start, but there are still a lot of other possibilities, bad gas valve coils, thermostat(s), timer etc. It could get expensive and frustrating guessing. I think this is the proper model number for your dryer, but not totally sure, 110.75922401. If you've removed the lower access panel and observed the gas valve ignition process, and the glow bar igniter does not come on and glow, at all, then you're on the right track. Good Luck, :) :) :)
