Discuss
Samsung dryer won't heat
 in
Dryer Repair
There is some thermostats that if bad, will prevent the heater from working. If you access the heater, you have
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Samsung dryer won't heat
  #11 (permalink)
Old 01-09-2014, 07:09 AM
Jeff / APP Team's Avatar
Senior Expert
Jeff / APP Team is on a distinguished road
Default
There is some thermostats that if bad, will prevent the heater from working. If you access the heater, you have 2 wires coming to it. Unplug both wires from the heater, and make sure they are not touching metal. Then test for power to each wire. Each wire should show 120 VAC. If not, trace the dead wire until you find the voltage. Then you have located the bad part in the unit.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Jeff K. / APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #12 (permalink)
Old 01-10-2014, 07:09 AM
Junior Member
Cablesplicer is on a distinguished road
Default Jeff app team
I tested for voltage as you said. Took the red and blue wire off the heater element....reading 120 V off each wire when turned on. I know the heater element is good. I know all three thermostats ohm good and even when as far as jumping across all of them did not produce heat. .
  #13 (permalink)
Old 01-10-2014, 07:15 AM
Senior Expert
Default
Ok, then you are either dropping ground, or the element is bad, but testing good. If the voltage is there, it should heat.
__________________
Jeff K. / APP TEAM
  #14 (permalink)
Old 01-10-2014, 08:12 AM
Junior Member
Default Jeff
when I put a ext. Cord on it get heat & it runs fine other then no heat
  #15 (permalink)
Old 01-10-2014, 08:14 AM
Senior Expert
Default
It needs 240 VAC to heat and an extension cord is 120 VAC. It is not going to heat with 120 VAC, but it will run.
__________________
Jeff K. / APP TEAM
  #16 (permalink)
Old 01-10-2014, 09:17 AM
Junior Member
Default Jeff
What's the thermistor do Samsung gv vague spec 10k@77F no good or bad range. original 1 & new 1 mtr 15k @ 50 degrees.
  #17 (permalink)
Old 01-10-2014, 09:21 AM
Senior Expert
Default
Post a question under the Question and Answers section on this part page. Include your email and I will send you some information to help you on this model. Thanks.
Part number: AP4201716
__________________
Jeff K. / APP TEAM
  #18 (permalink)
Old 01-10-2014, 10:56 AM
Junior Member
Great thank you
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Samsung Oven slow to heat lymansbay Oven Repair (including Ranges and Cooktops) 2 11-12-2011 06:41 AM
Samsung Dryer TuffyManJ Dryer Repair 0 06-09-2011 08:50 AM
Samsung Gas Dryer NOT DRYING jelliston Dryer Repair 0 05-17-2011 07:54 AM
Samsung Dryer where is the thermo jeffsc Dryer Repair 0 08-06-2010 08:11 AM
Samsung no heat Johnkut Microwave Repair 1 03-10-2009 05:01 PM
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
