Discuss
Whirlpool Dryer makes humming sound
 in
Dryer Repair
I have a gas dryer that when the start button is pressed, it will start sometimes and sometimes it will
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer makes humming sound
  #1 (permalink)
Old 03-23-2009, 11:20 AM
Junior Member
grice98 is on a distinguished road
Default Whirlpool Dryer makes humming sound
Model Number: LW1770W0   Brand: Whirlpool   Age: More than 10 years
I have a gas dryer that when the start button is pressed, it will start sometimes and sometimes it will make a humming sound. If I spin the drum a little by hand (not very easy to do) and then press the start button, it will work.
I have also removed the drum, belt, and Idler arm, so that the motor has no resistance and it exhibits the same behavior. If I take and turn the motor shaft while pressing the start button it will come on.
Any ideas? Thanks
Ads By Google
Related Models
Amana LW2001W Washer - Top Loading
Amana LW2001W2 Washer - Top Loading
Amana LW2201G Washer - Top Loading
Amana LW2201L Washer - Top Loading
Amana LW2201W Washer - Top Loading
Amana LW2300 Washer - Top Loading
Amana LW2302 Washer - Top Loading
Amana LW2303 Washer - Top Loading
Amana LW2400 Washer - Top Loading
Amana LW2402 Washer - Top Loading
Amana LW2403 Washer - Top Loading
Amana LW2500 Washer - Top Loading
Amana LW2501G Washer - Top Loading
Amana LW2501L Washer - Top Loading
Amana LW2501L2 Washer - Top Loading
Amana LW2501W Washer - Top Loading
Amana LW2501W2 Washer - Top Loading
Amana LW2502G Washer - Top Loading
Amana LW2502L Washer - Top Loading
Amana LW2502W Washer - Top Loading
Amana LW2503G Washer - Top Loading
Amana LW2503L Washer - Top Loading
Amana LW2503W Washer - Top Loading
Amana LW2600 Washer - Top Loading
Amana LW2602 Washer - Top Loading
Amana LW2603 Washer - Top Loading
Amana LW2800 Washer - Top Loading
Amana LW2802 Washer - Top Loading
Amana LW2900 Washer - Top Loading
Amana LW2902 Washer - Top Loading
Amana LW2903 Washer - Top Loading
Amana LW3302G Washer - Top Loading
Amana LW3302L Washer - Top Loading
Amana LW3302W Washer - Top Loading
Amana LW3303G Washer - Top Loading
Amana LW3303L Washer - Top Loading
Amana LW3303W Washer - Top Loading
Amana LW3403G Washer - Top Loading
Amana LW3403L Washer - Top Loading
Amana LW3403W Washer - Top Loading
Amana LW3502L Washer - Top Loading
Amana LW3502L2 Washer - Top Loading
Amana LW3502W Washer - Top Loading
Amana LW3502W2 Washer - Top Loading
Amana LW3503L Washer - Top Loading
Amana LW3503L2 Washer - Top Loading
Amana LW3503W Washer - Top Loading
Amana LW3503W2 Washer - Top Loading
Amana LW3603 Washer - Top Loading
Amana LW3603L Washer - Top Loading
Amana LW3603W Washer - Top Loading
Amana LW3903 Washer - Top Loading
Amana LW3903L Washer - Top Loading
Amana LW3903W Washer - Top Loading
Amana LW4202L Washer - Top Loading
Amana LW4202W Washer - Top Loading
Amana LW4203L2 Washer - Top Loading
  #2 (permalink)
Old 03-23-2009, 03:29 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
The motor needs replacing.
OR
The centrifugal switches on the motor are jammed up with lint.
OR
The centrifugal activating assembly is broken, also requires motor replacement.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool dryer won't turn on (humming sound)... gaimaster Dryer Repair 1 01-10-2010 02:31 PM
Dryer Makes Humming Sound ASTRO1954 Dryer Repair 4 03-15-2009 08:45 AM
disposal makes humming sound/won't work lilmama Garbage Disposer Repair 1 03-12-2009 04:24 PM
makes a humming sound when on angel4022 Oven Repair (including Ranges and Cooktops) 1 01-27-2009 11:10 AM
Dryer makes humming sound when turning cycle selector skull Dryer Repair 3 01-17-2009 09:15 AM
