Cleaned Gas Valve Openings/replaced Coils/have Continuity On Igniter/flame Sensor / High/low Temp Switch/drum Motor Turns/igniter Glows/gas Valve Clicks..then No Flow...have 6 Plus Ounces Preasure...........what Next
