| » whirlpool dryer LEQ8858JQ0 not heating |
Model Number: LEQ8858JQ0 Brand: Whirlpool Age: More than 10 years
whirlpool dryer LEQ8858JQ0 not heating...checked outside fuses, changed heating element and attached thermostat still no heat
You obviously have no volt/ohm meter. It gets really expensive when you guess. Get a cheap volt ohm meter at radio shack, and get back to us. We all would be glad to help. PS Have you checked the thermal fuse on top of the heater housing, also just because the dryer runs does not mean you have all the power. Tom ********************************************
Quote:
Next steps? |
More info...you can find some inteesting things inside a dryer, like the tech data sheet to access data codes. Mine is throwing the Heater Fault (no heat) E5B code (duh). It says to check the voltage across terminals on RL2 on the electronic control for 240v. If 240, replace control??? if zero continue with other diagnostics. I dont know what I hope to see when I do this, voltage that indicates $200 part or moving through more tests with a hopefulley cheaper outcome.
jdpk
First check that you are getting 240 at the plug. Sometimes you can loose half the line without actually tripping the breaker. Next check the heater. Disconnect both sides of it. Measure for resistance, should be around 10 ohms. Then measure each connector to the frame, both should be infinite. Then the high limit thermostat, should be 0 ohms. Then the thermistor, See the tech sheet. I always try to do the checks where the unit is unplugged first, why mess with 240 volts if you do not have to.
__________________
Denman
Thanks, the voltage looks good where it comes in from the wall. This is part of a stackable set about two years old, does the drum need to come out to get at the element? Frigidair model LEQ6000ES0 Update; the resistance across the high limit thrmostat is infinite when unit is not energized. thermister is supposed to be 50 ohm but looks to be way up front and I have not figured out how to get to it yet. Last edited by jdpk : 03-22-2009 at 11:02 AM. |
I'm an idiot. I read the meter wrong so the thermostat is likely good. Ended up taking the drum out to peek at the element and it was charred and broken at the 12 O'Clock position. I'm gonna hate doing this again in 2 1/2 years if the replacement part lasts as long (or not) as the stock element.
Clean and check your vent system.
Check the lint filter. Sometimes fabric softener will coat the screen, greatly reducing air flow. If it is coated, clean it with soap and water. Clean the lint filter every load. Check the drum seals. Check the blower wheel/fan This should extend the heating elements life as low air flow over it is the normal cause for a short life.
__________________
| Display Modes | |
| whirlpool dryer not heating | skats | Dryer Repair | 3 | 02-17-2011 04:22 PM |
| Whirlpool dryer not heating | davelions | Dryer Repair | 0 | 01-05-2010 02:31 PM |
| Whirlpool Dryer not heating | mangboy | Dryer Repair | 1 | 08-17-2009 04:53 AM |
| Whirlpool dryer not heating | distressed | Dryer Repair | 1 | 12-08-2008 11:26 AM |
| whirlpool gas dryer starts heating | ajoreid | Dryer Repair | 1 | 11-23-2008 05:30 AM |
