Discuss
gas not coming on
 in
Dryer Repair
i have a gas dryer that came with the home i moved into about a year ago.the dryer worked
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » gas not coming on
  #1 (permalink)
Old 11-21-2007, 07:01 AM
caccur43 caccur43 is offline
Junior Member
caccur43 is on a distinguished road
Default gas not coming on
Model Number: ddg6380balwh   Brand: GE   Age: More than 10 years
i have a gas dryer that came with the home i moved into about a year ago.the dryer worked good for 6 months then the belt that turns the drum broke.i got the parts i needed and repaired it (thanks to APP).I OPEN THE PANEL AND SAW SOME USED MATCH STICKS.i didnt think much about it at the time.the dryer turns but i dont here the gas coming on.this started about 2 weeks ago.it there a possibility that the previous owner had the same problem and used the matches to get the dryer working again(pilot light)maybe?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
no cold water alone coming in .do get hot or warm. so cold must be comin through valv misterfixall Washer Repair 1 11-16-2007 01:51 PM
Problem with cold water coming in kdickins Washer Repair 0 10-03-2007 02:11 PM
no heat coming from dryer chrisnross Dryer Repair 0 09-04-2007 08:36 PM
No Water Coming Into Dishwasher Momof3Girlz Dishwasher Repair 1 09-03-2007 09:11 PM
humming coming from the bottom of system ahchitski Dishwasher Repair 1 07-23-2007 04:03 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
