Discuss
Replaced dryer timer & it doesn't work
 in
Dryer Repair
Have put new timer in and doesn't clock. Assumed it was bad, so i got a second one. It
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Replaced dryer timer & it doesn't work
  #1 (permalink)
Old 03-20-2009, 08:55 AM
CLACOV CLACOV is offline
Junior Member
CLACOV is on a distinguished road
Default Replaced dryer timer & it doesn't work
Model Number: MDE6000AYW   Brand: Maytag   Age: 5 - 10 years
Have put new timer in and doesn't clock. Assumed it was bad, so i got a second one. It clocked once when I installed & then didn't work.t work again. Is there something that can be killing the timer?
Related Models
Maytag MDE6000AYW Dryer - Ele
Maytag MDE6000AZQ Dryer - Ele
Maytag MDE6000AZW Dryer - Ele
Maytag MDE6200AYQ Dryer - Ele
Maytag MDE6200AYW Dryer - Ele
Maytag MDE6200AZQ Dryer - Ele
Maytag MDE6200AZW Dryer - Ele
Maytag MDE6400AGW Dryer - Ele
Maytag MDE6400AYQ Dryer - Ele
Maytag MDE6400AYW Dryer - Ele
Maytag MDE6400AZW Dryer - Ele
Maytag MDE6460AYW Dryer - Ele
Maytag MDE6460AZW Dryer - Ele
Maytag MDE6657BYQ Dryer - Ele
Maytag MDE6657BYW Dryer - Ele
Maytag MDE6700AYW Dryer - Ele
Maytag MDE6700AZW Dryer - Ele
Maytag MDE6800AYB Dryer - Ele
Maytag MDE6800AYQ Dryer - Ele
Maytag MDE6800AYW Dryer - Ele
Maytag MDE6800AZQ Dryer - Ele
Maytag MDE6800AZW Dryer - Ele
Maytag MDE7057AYQ Dryer - Ele
Maytag MDE7057AYW Dryer - Ele
Maytag MDE7057AZW Dryer - Ele
Maytag MDE7400AYQ Dryer - Ele
Maytag MDE7400AYW Dryer - Ele
Maytag MDE7400AZQ Dryer - Ele
Maytag MDE7400AZW Dryer - Ele
Maytag MDE7460AYQ Dryer - Ele
Maytag MDE7460AYW Dryer - Ele
Maytag MDE7500AYQ Dryer - Ele
Maytag MDE7500AYW Dryer - Ele
Maytag MDE7500AZQ Dryer - Ele
Maytag MDE7500AZW Dryer - Ele
Maytag MDE7550AGW Dryer - Ele
International MDE7550AGW Dryer - Ele
Maytag MDE7600AUW Dryer - Ele
Maytag MDE7600AYQ Dryer - Ele
Maytag MDE7600AYW Dryer - Ele
Maytag MDE7600AZQ Dryer - Ele
Maytag MDE7600AZW Dryer - Ele
Maytag MDE7657AYQ Dryer - Ele
Maytag MDE7657AYW Dryer - Ele
Maytag MDE7657BYQ Dryer - Ele
Maytag MDE7657BYW Dryer - Ele
Maytag MDE7658AYQ Dryer - Ele
Maytag MDE7658AYW Dryer - Ele
Maytag MDE7658BYQ Dryer - Ele
Maytag MDE7658BYW Dryer - Ele
Maytag MDE7757AYQ Dryer - Ele
Maytag MDE7757AYW Dryer - Ele
Maytag MDE7758AYQ Dryer - Ele
Maytag MDE7758AYW Dryer - Ele
Maytag MDE8000AYQ Dryer - Ele
Maytag MDE8000AYW Dryer - Ele
Maytag MDE8000AZW Dryer - Ele
Maytag MDE8057AYQ Dryer - Ele
Maytag MDE8057AYW Dryer - Ele
Maytag MDE8057AZW Dryer - Ele
Maytag MDE8058AYQ Dryer - Ele
Maytag MDE8058AYW Dryer - Ele
Maytag MDE8400AYQ Dryer - Ele
Maytag MDE8400AYW Dryer - Ele
Maytag MDE8400AZW Dryer - Ele
Maytag MDE8416AYA Dryer - Ele
Maytag MDE8416AYW Dryer - Ele
International MDE8426AAW Dryer - Ele
International MDE8426AGW Dryer - Ele
Maytag MDE8500AYW Dryer - Ele
Maytag MDE8506AYA Dryer - Ele
Maytag MDE8506AYW Dryer - Ele
Maytag MDE8506AZW Dryer - Ele
International MDE8550AGW Dryer - Ele
International MDE8550BGW Dryer - Ele
Maytag MDE8600AYQ Dryer - Ele
Maytag MDE8600AYW Dryer - Ele
Maytag MDE8600AZQ Dryer - Ele
Maytag MDE8600AZW Dryer - Ele
Maytag MDE8757AYQ Dryer - Ele
Maytag MDE8757AYW Dryer - Ele
Maytag MDE9206AYA Dryer - Ele
Maytag MDE9206AYW Dryer - Ele
Maytag MDE9206AZW Dryer - Ele
Maytag MDE9306AUW Dryer - Ele
Maytag MDE9306AYA Dryer - Ele
Maytag MDE9306AYW Dryer - Ele
Maytag MDE9306AZA Dryer - Ele
Maytag MDE9306AZW Dryer - Ele
Maytag MDE9316AYA Dryer - Ele
Maytag MDE9316AYQ Dryer - Ele
Maytag MDE9316AYW Dryer - Ele
Maytag MDE9316AZW Dryer - Ele
Maytag MDE9357AYA Dryer - Ele
Maytag MDE9357AYQ Dryer - Ele
Maytag MDE9357AYW Dryer - Ele
Maytag MDE9360AYW Dryer - Ele
Maytag MDE9390AYW Dryer - Ele
Maytag MDE9390AZW Dryer - Ele
Maytag MDE9420AYW Dryer - Ele
Maytag MDE9420AZW Dryer - Ele
Maytag MDE9520AYQ Dryer - Ele
Maytag MDE9520AYW Dryer - Ele
Maytag MDE9520AZW Dryer - Ele
Maytag MDE9557AYA Dryer - Ele
Maytag MDE9557AYQ Dryer - Ele
Maytag MDE9557AYW Dryer - Ele
Maytag MDE9557AZA Dryer - Ele
Maytag MDE9557AZQ Dryer - Ele
Maytag MDE9557AZW Dryer - Ele
Maytag MDE9606AUW Dryer - Ele
Maytag MDE9606AYA Dryer - Ele
Maytag MDE9606AYQ Dryer - Ele
Maytag MDE9606AYW Dryer - Ele
Maytag MDE9606AZA Dryer - Ele
Maytag MDE9606AZQ Dryer - Ele
Maytag MDE9606AZW Dryer - Ele
Maytag MDE9700AYM Dryer - Ele
Maytag MDE9700AYQ Dryer - Ele
Maytag MDE9700AYW Dryer - Ele
  #2 (permalink)
Old 03-20-2009, 11:34 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Replacement parts for MAYTAG MDE6000AYW | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag...s/16023110.pdf
What was the original problem and symptoms?
__________________
  #3 (permalink)
Old 03-20-2009, 12:55 PM
Junior Member
Default
Wouldn't shut off regardless of timer setting, i.e. time or dryness
  #4 (permalink)
Old 03-20-2009, 01:31 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You will need to check your schematic to make sure you didn't put 230 volts to a 115 volt timer motor.
__________________
  #5 (permalink)
Old 03-20-2009, 07:50 PM
Senior Expert
APP Volunteer
Default
When you say it would not shut off do you mean:
It went past the Off position and continued to run
OR
The timer would not advance
And what is the problem with the current timer.
Do you have a meter, if you do start a timed dry cycle measure the voltage across the timer motor.
Be careful there is 240 volts in the control console which is very dangerous.
__________________
  #6 (permalink)
Old 03-23-2009, 06:05 AM
Junior Member
Default
Are there different timer models for 110 vs. 240? All i did was unplug one timer and plug in the new one. If 204 is hitting a 110 circuit, wouldn't I have more issues then the timer getting killed?
  #7 (permalink)
Old 03-23-2009, 06:09 AM
Junior Member
Default
Old, new and replacement new, don't run. Start dryer and it continues to run until manually shut off.
  #8 (permalink)
Old 03-23-2009, 07:10 AM
Senior Expert
APP Volunteer
Default
Only thing I can see that could cause this is the Electronic Dryness Control board OR a broken wire/poor connection.
Cannot find any decent info on this board but the Neyutral side og the timer does go through it.
With the unit unplugged.
On a low resistance scale (200 ohms)
Measure from the Neutral to the red wire on the Dryness control.
Should go to 0 ohms, when the Push TO Start is pressed.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE dryer timer wont work on automatic setting dirtracer9 Dryer Repair 2 11-26-2009 06:35 AM
Kenmore dryer timer doesnt work treed Dryer Repair 1 05-25-2009 06:48 AM
dryer timer/auto will not work FJM122 Dryer Repair 1 12-09-2008 10:23 AM
dryer timer auto cycles don't work mikedudl Dryer Repair 0 04-29-2008 09:52 AM
dryer runs,no heat,timer doesn't work dcar48 Dryer Repair 2 02-04-2008 12:10 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
