Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   my dryer takes forever to dry (http://forum.appliancepartspros.com/dryer-repair/270096-my-dryer-takes-forever-dry.html)
danahatch75 07-22-2011 08:56 PM
my dryer takes two cycles to dry one load
Jeff / APP Team 07-23-2011 08:13 AM
Hello danahatch75. It sounds like the venting system is clogged or kinked. You will need to check the vent and clean it out. Be sure and clean the vent pipe and the dryer air duct assembly. If the air flow is not good, the unit will retain moist air causing the clothes not to dry. Try running the unit with the vent unhooked from the back of the dryer and see if the dryer works properly. Hope this helps.
