Discuss
Dryer won't heat up to dry clothes
 in
Dryer Repair
I am having trouble with my dryer. It won't dry the clothes, not getting any heat. I just replaced the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't heat up to dry clothes
  #1 (permalink)
Old 07-21-2011, 04:55 PM
Junior Member
tdeai is on a distinguished road
Default Dryer won't heat up to dry clothes
Model Number: MDE5500AYW   Brand: Maytag   Age: 5 - 10 years
I am having trouble with my dryer. It won't dry the clothes, not getting any heat. I just replaced the heating element assembly and thermostat sensor but I am still not getting dry clothes.
Does anyone have any answers????
Tom
Related Models
Maytag MDE5500AYW DRYER- ELE
Maytag MDE5500AZQ DRYER- ELE
Maytag MDE5500AZW DRYER- ELE
Maytag MDE5806AYK DRYER- ELE
Maytag MDE5806AYW DRYER- ELE
Maytag MDE5806AZK DRYER- ELE
Maytag MDE5806AZW DRYER- ELE
Maytag MDE5960AYW DRYER- ELE
Maytag MDE6000AUW DRYER- ELE
Maytag MDE6000AYQ DRYER- ELE
Maytag MDE6000AYW DRYER- ELE
Maytag MDE6000AZQ DRYER- ELE
Maytag MDE6000AZW DRYER- ELE
Maytag MDE6200AYQ DRYER- ELE
Maytag MDE6200AYW DRYER- ELE
Maytag MDE6200AZQ DRYER- ELE
Maytag MDE6200AZW DRYER- ELE
Maytag MDE6400AGW DRYER- ELE
Maytag MDE6400AYQ DRYER- ELE
Maytag MDE6400AYW DRYER- ELE
Maytag MDE6400AZW DRYER- ELE
Maytag MDE6460AYW DRYER- ELE
Maytag MDE6460AZW DRYER- ELE
Maytag MDE6657BYQ DRYER- ELE
Maytag MDE6657BYW DRYER- ELE
Maytag MDE6700AYW DRYER- ELE
Maytag MDE6700AZW DRYER- ELE
Maytag MDE6800AYQ DRYER- ELE
Maytag MDE6800AYW DRYER- ELE
Maytag MDE6800AZQ DRYER- ELE
Maytag MDE6800AZW DRYER- ELE
Maytag MDE7057AYQ DRYER- ELE
Maytag MDE7057AYW DRYER- ELE
Maytag MDE7057AZW DRYER- ELE
Maytag MDE7400AYQ DRYER- ELE
Maytag MDE7400AYW DRYER- ELE
Maytag MDE7400AZQ DRYER- ELE
Maytag MDE7400AZW DRYER- ELE
Maytag MDE7460AYQ DRYER- ELE
Maytag MDE7460AYW DRYER- ELE
Maytag MDE7500AYQ DRYER- ELE
Maytag MDE7500AYW DRYER- ELE
Maytag MDE7500AZQ DRYER- ELE
Maytag MDE7500AZW DRYER- ELE
Admiral MDE7550AGW DRYER- ELE
Maytag MDE7600AUW DRYER- ELE
Maytag MDE7600AYQ DRYER- ELE
Maytag MDE7600AYW DRYER- ELE
Maytag MDE7600AZQ DRYER- ELE
Maytag MDE7600AZW DRYER- ELE
Maytag MDE7657AYQ DRYER- ELE
Maytag MDE7657AYW DRYER- ELE
Maytag MDE7657BYQ DRYER- ELE
Maytag MDE7657BYW DRYER- ELE
Maytag MDE7658AYQ DRYER- ELE
Maytag MDE7658AYW DRYER- ELE
Maytag MDE7658BYQ DRYER- ELE
Maytag MDE7658BYW DRYER- ELE
Maytag MDE7757AYQ DRYER- ELE
Maytag MDE7757AYW DRYER- ELE
Maytag MDE7758AYQ DRYER- ELE
Maytag MDE7758AYW DRYER- ELE
Maytag MDE8000AYQ DRYER- ELE
Maytag MDE8000AYW DRYER- ELE
Maytag MDE8000AZW DRYER- ELE
Maytag MDE8057AYQ DRYER- ELE
Maytag MDE8057AYW DRYER- ELE
Maytag MDE8057AZW DRYER- ELE
Maytag MDE8058AYQ DRYER- ELE
Maytag MDE8058AYW DRYER- ELE
Maytag MDE8400AYQ DRYER- ELE
Maytag MDE8400AYW DRYER- ELE
Maytag MDE8400AZW DRYER- ELE
Maytag MDE8416AYA DRYER- ELE
Maytag MDE8416AYW DRYER- ELE
Admiral MDE8426AAW DRYER- ELE
Admiral MDE8426AGW DRYER- ELE
Maytag MDE8500AYW DRYER- ELE
Maytag MDE8506AYA DRYER- ELE
Maytag MDE8506AYW DRYER- ELE
Maytag MDE8506AZW DRYER- ELE
Admiral MDE8550AGW DRYER- ELE
Admiral MDE8550BGW DRYER- ELE
Maytag MDE8600AYQ DRYER- ELE
Maytag MDE8600AYW DRYER- ELE
Maytag MDE8600AZQ DRYER- ELE
Maytag MDE8600AZW DRYER- ELE
Maytag MDE8757AYQ DRYER- ELE
Maytag MDE8757AYW DRYER- ELE
Maytag MDE9206AYA DRYER- ELE
Maytag MDE9206AYW DRYER- ELE
Maytag MDE9206AZW DRYER- ELE
Maytag MDE9306AUW DRYER- ELE
Maytag MDE9306AYA DRYER- ELE
Maytag MDE9306AYW DRYER- ELE
Maytag MDE9306AZA DRYER- ELE
Maytag MDE9306AZW DRYER- ELE
Maytag MDE9316AYA DRYER- ELE
Maytag MDE9316AYQ DRYER- ELE
Maytag MDE9316AYW DRYER- ELE
Maytag MDE9316AZW DRYER- ELE
Maytag MDE9357AYA DRYER- ELE
Maytag MDE9357AYW DRYER- ELE
Maytag MDE9360AYW DRYER- ELE
Maytag MDE9390AYW DRYER- ELE
Maytag MDE9390AZW DRYER- ELE
Maytag MDE9420AYW DRYER- ELE
Maytag MDE9420AZW DRYER- ELE
Maytag MDE9520AYQ DRYER- ELE
Maytag MDE9520AYW DRYER- ELE
Maytag MDE9520AZW DRYER- ELE
Maytag MDE9557AYA DRYER- ELE
Maytag MDE9557AYQ DRYER- ELE
Maytag MDE9557AYW DRYER- ELE
Maytag MDE9557AZA DRYER- ELE
Maytag MDE9557AZQ DRYER- ELE
Maytag MDE9557AZW DRYER- ELE
Maytag MDE9606AUW DRYER- ELE
Maytag MDE9606AYA DRYER- ELE
Maytag MDE9606AYQ DRYER- ELE
  #2 (permalink)
Old 07-22-2011, 05:18 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here are your parts includes a wiring diagram.
Replacement parts for MAYTAG MDE5500AYW DRYER- ELE | AppliancePartsPros.com
Did you replace the parts in an attempt to fix the no heat problem and did not do any troubleshooting but felt they were the most likely cause?
Also I am not sure what thermostat you replaced.
You have 2 thermostats in the heater circuit and also a thermistor (sensor) connected to the control board.
First I would check the power.
The heater requires the full 240 volts while the control, motor etc. only require 120 volts.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer not producing enough heat to dry clothes DeanaB Dryer Repair 1 04-03-2011 07:51 AM
Bosch Dryer No Heat for clothes Jake4321 Refrigerator & Freezer Repair 0 05-24-2010 05:37 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer won't dry clothes, NO HEAT candace52979 Dryer Repair 1 06-22-2009 03:39 AM
Gas clothes dryer no heat kwclark Dryer Repair 0 01-23-2009 12:23 PM
