Discuss
dryer making a buzzing sound
 in
Dryer Repair
when the dryer is running it makes a buzzing sound for a minuter or so, then it will stop. it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer making a buzzing sound
  #1 (permalink)
Old 07-21-2011, 06:53 AM
Junior Member
adamkorreckt is on a distinguished road
Default dryer making a buzzing sound
Model Number: SDE3606AYW   Brand: Maytag   Age: 5 - 10 years
when the dryer is running it makes a buzzing sound for a minuter or so, then it will stop. it does that off a on sometimes more or less.
I have replaced the rear rollers and found one of them was bad.but that didnt fix the buzzing problem.Should i replace the idler wheel, or the blower wheel. the blower wheel seemed to be on their tight.
Any helpl would be great ,thanks.
Related Models
Maytag SDE3606AYW DRYER- ELE
Maytag SDE3606AZW DRYER- ELE
Maytag SDE4000AYW DRYER- ELE
Maytag SDE4000AZW DRYER- ELE
Maytag SDE405DAYW DRYER- ELE
Maytag SDE4606AYW DRYER- ELE
Maytag SDE4606AZW DRYER- ELE
Maytag SDE505DAYQ DRYER- ELE
Maytag SDE505DAYW DRYER- ELE
Maytag SDE505DAZW DRYER- ELE
Maytag SDE515DAYW DRYER- ELE
Maytag SDE515DAZW DRYER- ELE
Maytag SDE5401AYW DRYER- ELE
Maytag SDE5401AZW DRYER- ELE
Maytag SDE5701AYQ DRYER- ELE
Maytag SDE5701AYW DRYER- ELE
Maytag SDE5701AZW DRYER- ELE
Maytag SDG2606AWW DRYER- GAS
Maytag SDG305DAWW DRYER- GAS
Maytag SDG3606AWQ DRYER- GAS
Maytag SDG3606AWW DRYER- GAS
Maytag SDG4000AWW DRYER- GAS
Maytag SDG405DAWW DRYER- GAS
Maytag SDG4606AWW DRYER- GAS
Maytag SDG505DAWQ DRYER- GAS
Maytag SDG505DAWW DRYER- GAS
Maytag SDG505DAXW DRYER- GAS
Maytag SDG515DAWW DRYER- GAS
Maytag SDG5401AWW DRYER- GAS
Maytag SDG5401AXW DRYER- GAS
Maytag SDG5701AWQ DRYER- GAS
Maytag SDG5701AWW DRYER- GAS
Maytag SDG5701AXW DRYER- GAS
Whirlpool SDH481B0 DEHUMIDIFIER
Whirlpool SDH501B20 DEHUMIDIFIER
Amana SDI22A REF - SXS/I&W
Amana SDI22A-A REF - SXS/I&W
Amana SDI22A-AG REF - SXS/I&W
Amana SDI22A-C REF - SXS/I&W
Amana SDI22B REF - SXS/I&W
Amana SDI22B-A REF - SXS/I&W
Amana SDI22B-C REF - SXS/I&W
Amana SDI22B-G REF - SXS/I&W
Amana SDI22B-L REF - SXS/I&W
Amana SDI22C REF - SXS/I&W
Amana SDI22C-A REF - SXS/I&W
Amana SDI22C-C REF - SXS/I&W
Amana SDI22C-G REF - SXS/I&W
Amana SDI22C-L REF - SXS/I&W
Amana SDI22D REF - SXS/I&W
Amana SDI22E REF - SXS/I&W
Amana SDI22E-1-A REF - SXS/I&W
Amana SDI22E-1-C REF - SXS/I&W
Amana SDI22E-A REF - SXS/I&W
Amana SDI22E-C REF - SXS/I&W
Amana SDI22E-G REF - SXS/I&W
Amana SDI22E-L REF - SXS/I&W
Amana SDI22E1 REF - SXS/I&W
Amana SDI22E1G REF - SXS/I&W
Amana SDI22E1L REF - SXS/I&W
Amana SDI22F Ref - SXS/I&W
Amana SDI22F-1 REF - SXS/I&W
Amana SDI22F-1-G REF - SXS/I&W
Amana SDI22F-1-L REF - SXS/I&W
Amana SDI22F-G Ref - SXS/I&W
Amana SDI22F-L Ref - SXS/I&W
Amana SDI22FA REF - SXS/I&W
Amana SDI22FC REF - SXS/I&W
Amana SDI22FG Ref - SXS/I&W
Amana SDI22FL Ref - SXS/I&W
Amana SDI22G Ref - SXS/I&W
Amana SDI22GG Ref - SXS/I&W
Amana SDI22GL REF - SXS/I&W
Amana SDI22N REF - SXS/I&W
Amana SDI22N-1 REF - SXS/I&W
Amana SDI22N-1-A REF - SXS/I&W
Amana SDI22N-1-AG REF - SXS/I&W
Amana SDI22N-1-C REF - SXS/I&W
Amana SDI22N-A REF - SXS/I&W
Amana SDI22N-AG REF - SXS/I&W
Amana SDI22N-C REF - SXS/I&W
Amana SDI22W REF - SXS/I&W
Amana SDI22W-A REF - SXS/I&W
  #2 (permalink)
Old 07-21-2011, 07:13 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Adam,
Sounds more like a dryer motor issue. The running gear wouldn't make a buzzing noise, but a bad motor winding could, as well as cause the motor to cease running. Or possibly a voltage drop,possibly due to a loose connection in the wiring to the dryer.
Thanks,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 07-21-2011, 08:37 AM
Junior Member
Default
Quote:
Originally Posted by Joe / APP Team View Post
Adam,
Thanks,
thanks for the advice i ll check it . i try to check the wiring.
i turn the dryer on with the drum out of it,and just let the motor run.
and it didnt make the buzzing noise. dont no if it is because the motor didnt have any strain aginst it.what do you think. the noise is coming from the motor or pulley couldnt really tell when i had it running. the shaft on the motor has some play on it in and out.
  #4 (permalink)
Old 07-21-2011, 12:23 PM
Senior Expert
Default
Adam,
There should only be a minimal amount of in and out motion on the motor shaft, (3/16 inch or less), a motor pulley, usually makes a clicking or ticking type noise, so I wouldn't start there. But if we have a motor bearing on the way out, the belt tension could create excess heat and cause the buzz noise and the switch to open and shut the motor down. I'm sure you have it figured out,and repaired soon.
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 07-21-2011, 12:26 PM
Junior Member
Default
Adam,
what do you think i should try first. new idler pulley or something else im missing. if the bearing goes out, the motor will lock up right.
  #6 (permalink)
Old 07-21-2011, 12:28 PM
Junior Member
Default
I no your busy so thanks for your help
  #7 (permalink)
Old 07-21-2011, 12:39 PM
Senior Expert
Default
Adam,
If it's not a high pitched squealing noise, or a clicking/ticking noise, not to worry about the idler or motor pulley. If that motor bearing is bad, it'll fail and the motor will lock up, That would be the easiest way to go, for now.
Drop us a line, once it fails and let us know what you find.
__________________
Joe M. APP TEAM
  #8 (permalink)
Old 07-21-2011, 12:40 PM
Junior Member
Default
Adam,
ok thank you for your time
  #9 (permalink)
Old 07-21-2011, 02:13 PM
Senior Expert
Default
My pleasure.
Hope to hear a report soon.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer makes buzzing sound ljkremer Dryer Repair 1 06-02-2011 06:37 AM
Jenn-Air Fridge & freezer not cooling at all & making a buzzing sound every 20-30 min amcarter32 Refrigerator & Freezer Repair 0 02-27-2011 08:20 AM
I need Help. Refridge is making a buzzing sound MikeJr Refrigerator & Freezer Repair 0 07-27-2010 06:00 PM
Dryer makes a buzzing sound when trying to start? romeo79 Dryer Repair 1 04-26-2009 06:39 AM
Kenmore making buzzing sound vanemburghj Refrigerator & Freezer Repair 3 04-18-2009 12:11 PM
