d Dryer won't stay on! Cleaned all the ventilation out. Still no success. It only stays on when you hold down the start button.
Check the start switch coil for continuity. The switch schematic is printed on its side. If the coil is open, replace the start switch. - The start switch Part number: AP2947429
