Dryer won't start. I have checked and cleared the thermostates, door switch, start switch. I checked the timer by connecting v meter to 2 black wires on the motor of the timer. In both the off position and the normal dry position the reading is 2.5 ohms. Does this timer need replaced? Thanks
