Discuss
Elec Dryer Stops after short time
 in
Dryer Repair
The dryer stops running after a short time. It will restart after 20-30 minutes. It appears to be an issue
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Elec Dryer Stops after short time
  #1 (permalink)
Old 03-18-2009, 07:29 PM
Junior Member
shews01 is on a distinguished road
Default Elec Dryer Stops after short time
Model Number: PYE2300AYW   Brand: Maytag   Age: 5 - 10 years
The dryer stops running after a short time. It will restart after 20-30 minutes. It appears to be an issue with overheating. I have changed the high-temp thermostat based on the most likely cause but that did not resolve the issue. The only diagrams I have are of general nature from the web. The Maytag user manual is useless. Any suggestions welcomed. Thanks.
Ads By Google
Related Models
Maytag PYE2300AYW Dryer - Ele
Maytag PYE2300AZW Dryer - Ele
International PYE3200AGW Dryer - Ele
Maytag PYE3200AYW Dryer - Ele
Maytag PYE3200AZW Dryer - Ele
International PYE3300AGW Dryer - Ele
International PYE3300AKW Dryer - Ele
Maytag PYE3300AYW Dryer - Ele
Maytag PYE3300AZW Dryer - Ele
Maytag PYE3360AYW Dryer - Ele
Maytag PYE4500AYQ Dryer - Ele
Maytag PYE4500AYW Dryer - Ele
Maytag PYE4500AZW Dryer - Ele
Maytag PYE4557AYW Dryer - Ele
Maytag PYE4558AYW Dryer - Ele
Maytag PYET244AYW Dryer - Ele
Maytag PYET244AZW Dryer - Ele
Maytag PYET344AYQ Dryer - Ele
Maytag PYET344AYW Dryer - Ele
Maytag PYET344AZW Dryer - Ele
Maytag PYET444AYQ Dryer - Ele
Maytag PYET444AYW Dryer - Ele
Maytag PYET444AZW Dryer - Ele
Maytag PYG1000AWW Dryer - Gas
Maytag PYG2000AWW Dryer - Gas
Maytag PYG2200AWW Dryer - Gas
International PYG2300AGW Dryer - Gas
Maytag PYG2300AWW Dryer - Gas
Maytag PYG3200AWW Dryer - Gas
Maytag PYG3250AWW Dryer - Gas
Maytag PYG3300AWW Dryer - Gas
Maytag PYG3360AWW Dryer - Gas
Maytag PYG4500AWQ Dryer - Gas
Maytag PYG4500AWW Dryer - Gas
Maytag PYG4557AWW Dryer - Gas
Maytag PYG4558AWW Dryer - Gas
International PYGS244AWW Dryer - Gas
Maytag PYGT244AWW Dryer - Gas
Maytag PYGT344AWW Dryer - Gas
Maytag PYGT444AWQ Dryer - Gas
Maytag PYGT444AWW Dryer - Gas
Amana QDO-695 Range - S/c S/i Ddraft Gas
Amana QDO-695D Range - S/c S/i Ddraft Gas
Amana QDO-695E Range - S/c S/i Ddraft Gas
Amana QDO-695F Range - S/c S/i Ddraft Gas
Amana QDO-695G Range - S/c S/i Ddraft Gas
Amana QDO-695H Range - S/c S/i Ddraft Gas
Amana QDU-838 Range - S/c S/i Ddraft Gas
Amana QDU-838A Range - S/c S/i Ddraft Gas
Amana QDU-838B Range - S/c S/i Ddraft Gas
Amana QDU-838C Range - S/c S/i Ddraft Gas
Amana QDU-838D Range - S/c S/i Ddraft Gas
Amana QDU-838G Range - S/c S/i Ddraft Gas
Amana QDU-858 Range - S/c S/i Ddraft Gas
Amana QDU-858A Range - S/c S/i Ddraft Gas
Amana QDU-858B Range - S/c S/i Ddraft Gas
Amana QDU-858C Range - S/c S/i Ddraft Gas
Amana QDU-858D Range - S/c S/i Ddraft Gas
Amana QDU-858E Range - S/c S/i Ddraft Gas
Amana QDU-858G Range - S/c S/i Ddraft Gas
Amana QDU-878 Range - S/c S/i Ddraft Gas
Amana QDU-878A Range - S/c S/i Ddraft Gas
Amana QDU-878B Range - S/c S/i Ddraft Gas
Amana QDU-966 Range - S/c S/i Ddraft Gas
Amana QDU-976 Range - S/c S/i Ddraft Gas
Amana QDU-976A Range - S/c S/i Ddraft Gas
Amana QKO-661 Range - S/c S/i Ddraft Gas
Amana QKO-661B Range - S/c S/i Ddraft Gas
Amana QKO-661C Range - S/c S/i Ddraft Gas
Amana QKO-661D Range - S/c S/i Ddraft Gas
Amana QKO-661E Range - S/c S/i Ddraft Gas
Amana QKO-751 Range - S/c S/i Ddraft Gas
Amana QKO-751A Range - S/c S/i Ddraft Gas
Amana QKU-647 Range - S/c S/i Ddraft Gas
Amana QKU-647A Range - S/c S/i Ddraft Gas
Amana QMC811 Walloven - Std Mwave Ele
Amana QMD-800 Mwave - Family Size (60 Hz)
Amana QMD-800A Mwave - Family Size (60 Hz)
Amana QMD-800B Mwave - Family Size (60 Hz)
Amana QMD-800C Mwave - Family Size (60 Hz)
Amana QMD-800D Mwave - Family Size (60 Hz)
Amana QMD-800E Mwave - Family Size (60 Hz)
Amana QMD-800G Mwave - Family Size (60 Hz)
Amana QMD-810 Mwave - Family Size (60 Hz)
Amana QMD-810A Mwave - Family Size (60 Hz)
Amana QMD800 Walloven - Std Mwave Ele
Amana QMD800D Mwave - Family Size (60 Hz)
Amana QMD810 Walloven - Std Mwave Ele
Amana R-1 Range - S/c S/i Ddraft Gas
Amana R-1H Range - S/c S/i Ddraft Gas
Amana R-1J Mwave - Family Size (60 Hz)
Amana R-2 Range - S/c S/i Ddraft Gas
Amana R-3 Mwave - Family Size (60 Hz)
Amana R0-24-8 Mwave - Mounted Over Range/wo
Whirlpool R101
Whirlpool R1011
Whirlpool R1012
Whirlpool R1013
Whirlpool R1014
Whirlpool R121
Whirlpool R1211
Whirlpool R1212
Whirlpool R1213
Whirlpool R1231
Whirlpool R141A
Whirlpool R141A1
Whirlpool R141F0
Whirlpool R141G0
Amana R15 Misc / Accessory
Whirlpool R153
Amana R15A Misc / Accessory
Amana R15L Misc / Accessory
Amana R15LA Misc / Accessory
Whirlpool R183
Whirlpool R183A
  #2 (permalink)
Old 03-19-2009, 02:25 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts, includes a wiring diagram
Replacement parts for MAYTAG PYE2300AYW | AppliancePartsPros.com
It sounds like the MOTOR PROTECTOR is tripping due to it's overheating.
Try turning the drum by hand it should turn fairly easily.
This checks that the motor is not being overloaded.
Open it up and clean the motor, it may be full of lint.
If both the above OK then it is the motor.
Note: that in most cases with this problem the motor must be replaced.
If it is the motor also check the rear rollers, the idler roller, the front glides, the drum seals, belt etc., so that you know the total cost of repair.
Might as well give it an overhaul.
Also sometimes the blower wheel must be replace as it gets destroyed trying to get if off.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer heats for short time shellbutton Dryer Repair 4 01-01-2010 07:45 AM
Dryer only heats for short periods of time, if at all. fred2117 Dryer Repair 3 05-01-2009 06:20 AM
Short Run Time smacha Refrigerator & Freezer Repair 4 03-20-2009 02:54 AM
dryer heats but runs for a short time suckleh0nny Dryer Repair 8 11-10-2008 07:42 PM
dryer quits running after a short time magictickler Dryer Repair 1 10-01-2007 02:48 AM
