My dryer stopped blowing hot air. Found that the thermal fuse attached to the heating element casing had blown (no continuity). I replaced it. It worked fine for a few loads, then developed the same problem. Rechecked and found the same problem ( the replacement thermal fuse had blown again - no continuity). Any ideas what is causing this?
