Discuss
thermostat?
 in
Dryer Repair
Roper electric dryer runs hot all the time, no low or medium heat. Need new thermostat? A job for owner?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » thermostat?
  #1 (permalink)
Old 03-18-2009, 10:57 AM
Junior Member
jenny55 is on a distinguished road
Angry thermostat?
Model Number: RES7648KQ0   Brand: Roper   Age: 5 - 10 years
Ads By Google
Related Models
Whirlpool RES7648KQ0
Whirlpool RES7648KQ1
Whirlpool RES7745PQ0 29"electric Dryer
Whirlpool RES7745RQ0 29"electric Dryer
Whirlpool RES7745RQ1 29"electric Dryer
Maytag RESF3330DB Range - S/c F/s Ele
Maytag RESF3330DW Range - S/c F/s Ele
Maytag RESF5330DT Range - S/c F/s Ele
Whirlpool REX2614LQ0 29"electric Dryer
Whirlpool REX3514PQ0 29"electric Dryer
Whirlpool REX3514RQ0 29"electric Dryer
Whirlpool REX3514RQ1 29"electric Dryer
Whirlpool REX3519PQ0 29" Electric Dryer
Whirlpool REX3614JW0
Whirlpool REX3614KW0
Whirlpool REX3614KW1
Whirlpool REX3614KW2 29" Electric Dryer
Whirlpool REX3614PW0 29" Electric Dryer
Whirlpool REX3614PW1 29" Electric Dryer
Whirlpool REX3614PW2 29" Electric Dryer
Whirlpool REX3615EW0
Whirlpool REX3615EW1
Whirlpool REX3615EW2
Whirlpool REX4625EN0
Whirlpool REX4625EW0
Whirlpool REX4625EW1
Whirlpool REX4625EW2
Whirlpool REX4634JQ0
Whirlpool REX4634KQ0
Whirlpool REX4634KQ1
Whirlpool REX4634KQ2 29" Electric Dryer
Whirlpool REX4635EN0
Whirlpool REX4635EN1
Whirlpool REX4635EN2
Whirlpool REX4635EQ0
Whirlpool REX4635EQ1
Whirlpool REX4635EQ2
Whirlpool REX4635EW0
Whirlpool REX4635EW1
Whirlpool REX4635EW2
Whirlpool REX5634JQ0
Whirlpool REX5634KQ0
Whirlpool REX5634KQ1
Whirlpool REX5634KQ2 29" Electric Dryer
Whirlpool REX5634PQ0 29" Electric Dryer
Whirlpool REX5634PQ1 29" Electric Dryer
Whirlpool REX5634RQ0 29" Electric Dryer
Whirlpool REX5635EN0
Whirlpool REX5635EN1
Whirlpool REX5635EN2
Whirlpool REX5635EQ0
Whirlpool REX5635EQ1
Whirlpool REX5635EQ2
Whirlpool REX5635EW0
Whirlpool REX5635EW1
Whirlpool REX5635EW2
Whirlpool REX5636AL0
Whirlpool REX5636AL1
Whirlpool REX5636AL2
Whirlpool REX5636AW0
Whirlpool REX5636AW1
Whirlpool REX5636AW2
Whirlpool REX6634PQ0 29" Electric Dryer
Whirlpool REX6634RQ0 29" Electric Dryer
Whirlpool REX6634RQ1 29" Electric Dryer
Whirlpool REX6646AL0
Whirlpool REX6646AL1
Whirlpool REX6646AL2
Whirlpool REX6646AL3
Whirlpool REX6646AQ2
Whirlpool REX6646AQ3
Whirlpool REX6646AW0
Whirlpool REX6646AW1
Whirlpool REX6646AW2
Whirlpool REX6646AW3
Whirlpool RF0100XKW0
Whirlpool RF0100XKW1
Whirlpool RF0100XRN8
Whirlpool RF0100XRW0
Whirlpool RF0100XRW1
Whirlpool RF0100XRW2
Whirlpool RF0100XRW3
Whirlpool RF0100XRW4
Whirlpool RF0100XRW5
Whirlpool RF0100XRW7
Whirlpool RF0100XRW8
Whirlpool RF0100XRW9
Whirlpool RF010EXPW0
Whirlpool RF010EXRW0
Whirlpool RF010EXRW1
Whirlpool RF010EXRW2
Whirlpool RF014PXRW0
Whirlpool RF110AXSQ0 30" Electric Freestanding Standard Clean Range
Whirlpool RF110AXSQ1 30" Electric Freestanding Standard Clean Range
Whirlpool RF110AXST0 30" Electric Freestanding Standard Clean Range
Whirlpool RF110AXST1 30" Electric Freestanding Standard Clean Range
Whirlpool RF111PXSQ0 30" Electric Freestanding Standard Clean Range
Whirlpool RF111PXSQ1 30" Electric Freestanding Standard Clean Range
Whirlpool RF111PXSW0 30" Electric Freestanding Standard Clean Range
Whirlpool RF111PXSW1 30" Electric Freestanding Standard Clean Range
Whirlpool RF114PXSB0 30" Electric Freestanding Standard Clean Range
Whirlpool RF114PXSB1 30" Electric Freestanding Standard Clean Range
Whirlpool RF114PXSB2 30" Electric Freestanding Standard Clean Range
Whirlpool RF114PXSQ0 30" Electric Freestanding Standard Clean Range
Whirlpool RF114PXSQ1 30" Electric Freestanding Standard Clean Range
Whirlpool RF114PXSQ2 30" Electric Freestanding Standard Clean Range
Whirlpool RF114PXST0 30" Electric Freestanding Standard Clean Range
Whirlpool RF114PXST1 30" Electric Freestanding Standard Clean Range
Whirlpool RF114PXST2 30" Electric Freestanding Standard Clean Range
Whirlpool RF196LXJQ0
Whirlpool RF196LXJT0
Whirlpool RF196LXKB0
Whirlpool RF196LXKB1 30" Electric Ceran Freestanding Range Self Clean
Whirlpool RF196LXKP0
Whirlpool RF196LXKP1 30" Electric Ceran Freestanding Range Self Clean
Whirlpool RF196LXKQ0
Whirlpool RF196LXKQ1 30" Electric Ceran Freestanding Range Self Clean
Whirlpool RF196LXKT0
Whirlpool RF196LXKT1 30" Electric Ceran Freestanding Range Self Clean
Whirlpool RF196LXMB0 30" Electric Ceran Freestanding Range Self Clean Oven
  #2 (permalink)
Old 03-19-2009, 03:05 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL RES7648KQ0 | AppliancePartsPros.com
Here is a wiring diagram
https://www.servicematters.com/docs/...%203406692.pdf
Here is a good site with basic dryer repair info
http://www.applianceaid.com/dryers.html
A job for owner?
Depends on how handy you are and how much effort you want to put in.
This is a possibility. The Operating Thermostat has a small heater built into it, on lower heat settings this heater is turned on. This adds heat to the thermostat, it turns off more often and this reduces the dryer heat.
So if it is open you get only high heat.
The thermostat's heater also has a variable resistor (cycle switch) in series with it, this varies the heat output of this heater.
First check your vent system
Undo the dryer from the exhaust
Run a load
If the unit now has low heat then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
Unplug the machine for the following;
Next remove the wires from the main heating coil. Measure with a meter from each heat contact to ground. Should be an open circuit. This is checking for a grounded element re: it has sagged or broken and is touching the case so it is always on. You could remove the heater assembly and check it visually.
Next remove one wire from the thermostat's heater and measure it's resistance, Should be approximately 7,000 ohms.
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
__________________
  #3 (permalink)
Old 03-19-2009, 05:48 AM
Junior Member
Default thanks
very helpful - thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
bad thermostat te4mundt Oven Repair (including Ranges and Cooktops) 1 02-12-2009 01:32 PM
bought new thermostat and heater thermostat and now won't heat at all mgilbert6 Dryer Repair 0 09-07-2008 09:58 AM
Thermostat, fix #23 cfdmedic71 Oven Repair (including Ranges and Cooktops) 0 06-30-2008 07:39 AM
Thermostat Kodiak Oven Repair (including Ranges and Cooktops) 5 05-20-2008 09:18 PM
