| » Dryer runs for 15 seconds, stops, & then won't restart |
Model Number: 110.66922500 Brand: Kenmore Age: 5 - 10 years
When I press the start button the dryer turns on and runs for about 15 seconds, gets louder, then shuts off. When I try and restart the dryer, it will not respond.
Sounds like the motor is bad. There is a overload built into the motor. If the motor gets hot or draws to many amps it will kill the power to the motor. The overload will reset itself after awhile. The motor could be full of lint, but I would guess for the short amount of time it runs before cutting out it has a bad bearing or start winding. You could open the dryer up and check for lint build up. Clean the lint out and try it again, but I'm guessing you will need to replace the motor to repair it.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
| Display Modes | |
| Maytag Dryer Stops after 30 seconds | austein | Dryer Repair | 5 | 04-18-2011 10:58 AM |
| Dryer runs for 30 seconds and stops | vbodin310 | Dryer Repair | 1 | 01-24-2010 07:23 AM |
| Gas Dryer runs 5 seconds and turns off | rseward | Dryer Repair | 0 | 01-02-2009 03:57 PM |
| DW runs for 15 seconds and stops | verbeek1 | Dishwasher Repair | 1 | 06-23-2008 08:56 PM |
| Electric dryer Stops, then will restart | croberts | Dryer Repair | 3 | 01-04-2008 01:21 AM |
