Discuss
Changing from 3 prong to 4 prong
 in
Dryer Repair
Trying to change from 3 prong to 4 prong. Not sure how to rewire as the colors don't match on
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Changing from 3 prong to 4 prong
  #1 (permalink)
Old 07-18-2011, 03:31 PM
Junior Member
grancheryl is on a distinguished road
Default Changing from 3 prong to 4 prong
Model Number: LER331DSO   Brand: Frigidaire   Age: 5 - 10 years
Trying to change from 3 prong to 4 prong. Not sure how to rewire as the colors don't match on dryer and new 4 prong plug. Back of dryer has green ground wire and then red, green and neutral wire. New 4 prong plug has green, red, black and white. When I attached new plug dryer does not work. Help!
Related Models
Admiral LER3330AAB RANGE- S/C F/S ELE
Admiral LER3330AAW RANGE- S/C F/S ELE
Admiral LER3330AAZ RANGE- S/C F/S ELE
Whirlpool LER3422AW0 Residential Dryer
Whirlpool LER3424AW0 Residential Dryer
Whirlpool LER3622BN0 COMPACT ELECTRIC DRYER
Whirlpool LER3622BW0 COMPACT ELECTRIC DRYER
Whirlpool LER3622DQ1 COMPACT ELECTRIC DRYER
Whirlpool LER3622DQ2 COMPACT ELECTRIC DRYER
Whirlpool LER3622DZ1 COMPACT ELECTRIC DRYER
Whirlpool LER3622DZ2 COMPACT ELECTRIC DRYER
Whirlpool LER3622HQ0 DRYER
Whirlpool LER3622HQ1 RESIDENTIAL DRYER
Whirlpool LER3622PQ0 COMPACT ELECTRIC DRYER
Whirlpool LER3622PQ1 COMPACT ELECTRIC DRYER
Whirlpool LER3622PQ2 COMPACT ELECTRIC DRYER
Whirlpool LER3624BN2 ELECTRIC DRYER
Whirlpool LER3624BN3 ELECTRIC DRYER
Whirlpool LER3624BW0 ELECTRIC DRYER
Whirlpool LER3624BW1 ELECTRIC DRYER
Whirlpool LER3624BW2 ELECTRIC DRYER
Whirlpool LER3624BW3 ELECTRIC DRYER
Whirlpool LER3624DQ0 DRYER
Whirlpool LER3624DQ1 ELECTRIC DRYER
Whirlpool LER3624DQ2 ELECTRIC DRYER
Whirlpool LER3624DZ0 DRYER
Whirlpool LER3624DZ2 ELECTRIC DRYER
Whirlpool LER3624EQ0 LAUNDRY DRYERS
Whirlpool LER3624EQ1 ELECTRIC DRYER
Whirlpool LER3624JQ0 DRYER
Whirlpool LER3624JQ1 RESIDENTIAL DRYER
Whirlpool LER3624JQ2 29" ELECTRIC DRYER
Whirlpool LER3624PQ0 29" ELECTRIC DRYER
Whirlpool LER3624PQ1 29" ELECTRIC DRYER
Whirlpool LER3634EW0 ELECTRIC DRYER
Whirlpool LER3634EW1 DRYERS
Whirlpool LER3634EW2 ELECTRIC DRYER
Whirlpool LER3634JW0 ELECTRIC DRYER
Whirlpool LER3634JW1 RESIDENTIAL DRYER
Admiral LER3725AAC RANGE- S/C F/S ELE
Whirlpool LER4434AN0 ELECTRIC DRYER
Whirlpool LER4434AN1 ELECTRIC DRYER
Whirlpool LER4434AQ0 Residential Dryer
Whirlpool LER4434AQ1 ELECTRIC DRYER
Whirlpool LER4434AW0 Residential Dryer
Whirlpool LER4434AW1 ELECTRIC DRYER
Whirlpool LER4436AW0 Residential Dryer
Whirlpool LER4600PQ0 29" ELECTRIC DRYER
Whirlpool LER4600PQ1 29" ELECTRIC DRYER
Whirlpool LER4624BN0 ELECTRIC DRYER
Whirlpool LER4624BN1 ELECTRIC DRYER
Whirlpool LER4624BN2 ELECTRIC DRYER
Whirlpool LER4624BQ0 ELECTRIC DRYER
Whirlpool LER4624BQ1 ELECTRIC DRYER
Whirlpool LER4624BQ2 ELECTRIC DRYER
Whirlpool LER4624BW0 ELECTRIC DRYER
Whirlpool LER4624BW1 ELECTRIC DRYER
Whirlpool LER4624BW2 ELECTRIC DRYER
Whirlpool LER4624DQ0 ELECTRIC DRYER
Whirlpool LER4624DQ1 ELECTRIC DRYER
Whirlpool LER4624DZ0 ELECTRIC DRYER
Whirlpool LER4624DZ1 ELECTRIC DRYER
Whirlpool LER4634BQ0 ELECTRIC DRYER
Whirlpool LER4634BQ1 ELECTRIC DRYER
Whirlpool LER4634BQ2 ELECTRIC DRYER
Whirlpool LER4634DQ0 DRYERS
Whirlpool LER4634DQ1 ELECTRIC DRYER
Whirlpool LER4634DZ0 DRYERS
Whirlpool LER4634DZ1 ELECTRIC DRYER
Whirlpool LER4634EQ0 ELECTRIC DRYER
Whirlpool LER4634EQ1 DRYERS
Whirlpool LER4634EQ2 ELECTRIC DRYER
Whirlpool LER4634EW0 ELECTRIC DRYER
Whirlpool LER4634EZ0 ELECTRIC DRYER
Whirlpool LER4634EZ1 DRYERS
Whirlpool LER4634EZ2 ELECTRIC DRYER
Whirlpool LER4634JQ0 ELECTRIC DRYER
Whirlpool LER4634JQ1 RESIDENTIAL DRYER
Whirlpool LER4634JQ2 29" ELECTRIC DRYER
Whirlpool LER4634JT0 ELECTRIC DRYER
Whirlpool LER4634JT1 RESIDENTIAL DRYER
Whirlpool LER4634JT2 29" ELECTRIC DRYER
Whirlpool LER4634JZ0 ELECTRIC DRYER
Whirlpool LER4634PQ0 29" ELECTRIC DRYER
Whirlpool LER4634PQ1 29" ELECTRIC DRYER
Whirlpool LER4634PT0 29" ELECTRIC DRYER
Whirlpool LER4634PT1 29" ELECTRIC DRYER
Whirlpool LER5434AW0 Residential Dryer
Whirlpool LER5600HQ0 ELECTRIC DRYER
Whirlpool LER5600HZ0 ELECTRIC DRYER
Whirlpool LER5600JQ0 ELECTRIC DRYER
Whirlpool LER5600JT0 ELECTRIC DRYER
Whirlpool LER5620KQ0 RESIDENTIAL DRYER
Whirlpool LER5620KQ1 ELECTRIC DRYER
Whirlpool LER5620KQ2 29"ELECTRIC DRYER
Whirlpool LER5624BN0 ELECTRIC DRYER
Whirlpool LER5624BN1 ELECTRIC DRYER
Whirlpool LER5624BN2 ELECTRIC DRYER
Whirlpool LER5624BW0 ELECTRIC DRYER
Whirlpool LER5624BW1 ELECTRIC DRYER
Whirlpool LER5624BW2 ELECTRIC DRYER
Whirlpool LER5624DQ0 DRYERS
Whirlpool LER5624DQ1 ELECTRIC DRYER
Whirlpool LER5624DW1 ELECTRIC DRYER
Whirlpool LER5624DZ0 DRYERS
Whirlpool LER5624DZ1 ELECTRIC DRYER
Whirlpool LER5634AN0 ELECTRIC DRYERS
Whirlpool LER5634AQ0 ELECTRIC DRYER
Whirlpool LER5634AQ1 ELECTRIC DRYER
Whirlpool LER5634AQ2 ELECTRIC DRYER
Whirlpool LER5634AW0 ELECTRIC DRYERS
Whirlpool LER5634DQ1 DRYER
Whirlpool LER5634EQ0 ELECTRIC DRYER
Whirlpool LER5634EZ0 ELECTRIC DRYER
Whirlpool LER5634LG0 RESIDENTIAL DRYER
Whirlpool LER5634LQ0 29" ELECTRIC DRYER
Whirlpool LER5634LT0 RESIDENTIAL DRYER
Whirlpool LER5634LW0 RESIDENTIAL DRYER
Whirlpool LER5635LQ0 29"ELECTRIC DRYER
Whirlpool LER5635LQ1 29"ELECTRIC DRYER
  #2 (permalink)
Old 07-19-2011, 03:20 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here is a wiring diagram
http://manuals.frigidaire.com/prodin...er/1340548.pdf
Your unit's wiring does not match the wiring diagram so I can only give general info.
The color code is:
Red = L1
Black = L2
White = Neutral
Green = Earth Ground
On most unit's terminal strip L1 and L2 are on the outside terminals and Neutral is the center terminal.
When switching from 3 to 4 wire the ground strap that goes from Neutral terminal to the machine frame has to be removed and the green from the line cord gets attached to the frame. Now he Neutral and earth ground are separate.
Have you checked the power at the plug?
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer machine power cord 3 prong missing ground prong REplace? Is it ok? maddy Washer Repair 1 06-17-2011 04:36 PM
Changeing a 3 prong to a 4 prong power cord Manteus26 Dryer Repair 1 12-23-2010 03:55 AM
changing from a 3 prong to a 4 prong plug. basspro78 Dryer Repair 1 09-21-2010 03:22 AM
Help changing a 3 prong to a 4 prong (dryer) plug Micheline Dryer Repair 4 11-28-2009 08:27 PM
Jenn-Air cartridge retro-fit 3 prong/4 prong vfxmark Oven Repair (including Ranges and Cooktops) 0 01-02-2008 09:32 AM
