At the start of the problem- After drying a load of clothes, and putting in another load, dryer makes buzzing noise when turning switch to turn on dryer and will not turn on, would turn back on later when dryer cooled. Now dryer is stopping after being turned on and working briefly, when try to turn back on get buzzing noise and won't turn back on again, often will be several hours before it will turn on again. Sometimes there is squeaking noises with dryer is working.
