Discuss
Kenmore dryer only starts at certain times
 in
Dryer Repair
I have a Kenmore 80 Series Heavy Duty dryer. The problem began about 6 months ago when the dryer timer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore dryer only starts at certain times
  #1 (permalink)
Old 03-16-2009, 07:07 PM
Junior Member
joeman17 is on a distinguished road
Default Kenmore dryer only starts at certain times
Brand: -brand-   Age: Less than 1 year
I have a Kenmore 80 Series Heavy Duty dryer. The problem began about 6 months ago when the dryer timer would time down and spin right through the off period and into the next cycle which was 'no heat' before ceasing after that cycle which was about 30 minutes or so. Sometimes the only way the machine would stop was to open the dryer door. Then the timer began to only start on certain times such as 27 minutes, 64 minutes or whatever for that matter and then time down. Sometimes the timer would cease after a few minutes and dryer would shut off. Most recently the dryer will only start when the timer is placed at about 15 minutes or so. We get heat for 5 minutes then the cool down cycle before the timer ceases at the off period. We have manually mmove the timer back to 15 minutes and restart the process and do this for 5-6 times before we have dry clothes. Any suggestions on the problem?
Ads By Google
  #2 (permalink)
Old 03-17-2009, 02:38 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Sounds like the timer is shot
A Model Number may help others help you as we have to look up the wiring diagram
Model Number Locator
__________________
  #3 (permalink)
Old 03-17-2009, 06:01 AM
Junior Member
Default
According to the tag inside the front door, the model number is: Model/Stock No. 96588210 65882. In advance, thanks for the help.
  #4 (permalink)
Old 03-17-2009, 06:06 AM
Senior Expert
APP Volunteer
Default
Sorry cannot find any info using given numbers
Tried here, the Kenmore site and another site.
__________________
  #5 (permalink)
Old 03-17-2009, 07:17 PM
Junior Member
Default
I have a serial number...but I imagine that would be of little help. However would it be helpful and/or specific enough if I were to provide the numbers that are printed on the timer. I can retrieve most numbers from the timer as it sits and can remove it to get a better view.
  #6 (permalink)
Old 03-17-2009, 07:33 PM
Senior Expert
APP Volunteer
Default
Call AppliancePartsPros they may be able to find the timer.
As to the timer numbers, it's worth a shot.
I will do the best I can to find a cross reference
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore dryer starts and stops fred ziffel Dryer Repair 1 11-10-2009 03:59 PM
Kenmore dryer starts, then stops quikduk Dryer Repair 4 10-31-2009 10:38 AM
Kenmore dryer starts up to dry then quits after a few minutes? denny9526 Dryer Repair 5 09-14-2009 06:30 AM
Kenmore Dryer: starts off hot then cools during cycle 73Ghia Dryer Repair 2 08-21-2009 03:00 AM
Kenmore gas dryer starts, heats, shuts off early jcpendergast Dryer Repair 2 08-17-2009 02:25 PM
