Discuss
Dryer heats while not running
 in
Dryer Repair
moved to a new house and had to put a longer power cable on the dryer as the 220 outlet
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer heats while not running
  #1 (permalink)
Old 11-19-2007, 06:58 PM
notatwit notatwit is offline
Junior Member
notatwit is on a distinguished road
Default Dryer heats while not running
Brand: -brand-   Age: More than 10 years
moved to a new house and had to put a longer power cable on the dryer as the 220 outlet is high up on the wall and needed a 6 footer as opposed to the 3 footer. it's a 3 wire cord and I hooked it up with minimal issues. weird problem though, when the dryer runs, it only blows warm'ish air not hot. once I turn off the dryer and leave the door open and return say, 20 minutes later, the dryer body itself, inside and outside, is burning hot whereas during operation, it was barely warm. I then unplug the power cable and it cools off. how weird is this and what can I do???? any help is appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
Dryer heats sometimes TommyC Dryer Repair 1 10-27-2007 01:44 PM
dryer heats but not hoy danandlisa1 Dryer Repair 0 10-09-2007 03:55 PM
dryer heats but drum dont get warm weity Dryer Repair 4 09-16-2007 07:57 AM
Dryer only heats once abe Dryer Repair 1 09-16-2007 12:00 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
